Understanding Gear Windage Loss
  • Thread starter Thread starter Analysis
    Gear Loss
Gear windage loss refers to the power loss experienced when gears rotate in an oil/air mixture within a gearbox, often exacerbated by the viscosity of the lubricant used. This phenomenon is similar to the horsepower loss seen in internal combustion engines due to crankshaft windage, where oil creates parasitic drag. The discussion highlights that gear windage loss can be difficult to quantify due to the complexities of fluid dynamics involved, particularly when gears are partially submerged in oil. Engineers have developed solutions, like windage trays, to mitigate these losses in engines. Understanding gear windage loss is crucial for optimizing performance in mechanical systems.
Analysis
Dear all
Anybody define,what is exactly gear windage loss?
Text books defined that loss due to lubricants etc...vague
Thanking u
Prakash
i can not address GEAR windage loss but i can tell you that internal combustion engines suffer horsepower loss caused by motor oil from the crankcase. Crankshaft windage blows oil (windgage) and the oil attaches to the crankshaft, this parasitic drag robs 15 horsepower. Chrysler engineers made a sheet metal windage tray with drain holes for the oil returning from the top of the engine (valve train). Oil in this case SEA 50 weight , is pretty thick,,SAE 90 gear oil is a lot thicker...if ther gears are spinning fast and the lube is a few inches below or at gear level,,it is something to look at
Gear windage is the portion of overall power required to rotate a gear set in the oil/air atmosphere inside the gear box. Sometimes, it can also include (depending on who you talk to) losses if the gearing comes in contact with the oil reservoir level, i.e. it is partially submerged. This can be very tough to actually calculate because it is somewhat like a fluid dynamics problem but the fluid is a 2 phase mixture of air and oil. Getting good values of properties like density and viscosity can be tough.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
