Gen Chem II Voltaic Cells question, not homework
In a Voltaic cell, oxidation occurs at the anode (left side), generating electrons and making it negatively charged, while reduction occurs at the cathode (right side), which consumes the electrons. The movement of electrons from the anode to the cathode results in a current that flows in the opposite direction, from cathode to anode. Clarification is provided that while electrons flow one way, the conventional current is considered to flow the other way, representing positive charge transfer. The discussion emphasizes the need for clarity on the half-cell reactions and the materials used in each jar to fully understand the setup. Understanding these concepts is crucial for grasping the functioning of galvanic cells.
th3plan
Im try to make sure i understand something right. I have two jars on the left is oxidation takes place and on right reduction takes place. A wire connects them to allow electrons to move. electrons move from left side to right side. This makes the left side negative cause it produces electrons. The right side is cathode, it uses the electrons. So since it moves like this the current would run in the opposite direction. Am i correct ? Cause by my books picture, it seems the get the orientation wrong then, or am i wrong ?
It's coursework ("Chem II"). Still belongs here.
Could you please scan your book's figure, and upload it here?
One possible clarification is that "current" flows in one direction, but electrons flow in the opposite direction. Current is associated with the transfer of positive charge.
Interpreting the electrode processes is based on reduction occurring at the electrode called the Cathode; and "oxidation" occurring at the electrode called the "Anode". Your topic title indicates "Voltaic" cell, from memory being same as "galvanic" cell; so this means your system is spontaneously creating electron flow on its own. Tell us your two Half-Cell reactions; in other words, tell us what solution and electrode material you have on each of the Left side and the Right side?
Thread 'Confusion regarding a chemical kinetics problem'
TL;DR Summary: cannot find out error in solution proposed. [![question with rate laws][1]][1] Now the rate law for the reaction (i.e reaction rate) can be written as: $$ R= k[N_2O_5] $$ my main question is, WHAT is this reaction equal to? what I mean here is, whether $$k[N_2O_5]= -d[N_2O_5]/dt$$ or is it $$k[N_2O_5]= -1/2 \frac{d}{dt} [N_2O_5] $$ ? The latter seems to be more apt, as the reaction rate must be -1/2 (disappearance rate of N2O5), which adheres to the stoichiometry of the...
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
