General question about wavefunctions
phi1123
Is it possible given a wavefunction ψ(x,t) to find the probability that the particle is at a particular location over an interval of time?
Intuitively, given that the probability of finding the particle in a region a<x<b at a time t is ∫ab|ψ(x,t)|2dx, i would guess that the probability of finding the particle ti<t<tf at the point x would be ∫titf|ψ(x,t)|2dx. However, this leads to a bit of a paradox: this integral can leads to probabilities greater than 1, which would suggest that I am missing something pretty critical.
Hi.
If you observe the position at t=ti wave function changes or contracts so it is a mess.
If you do not observe, you cannot say anything about position at t = ti or about staying in point x.
Regards.
To solve this, I first used the units to work out that a= m* a/m, i.e. t=z/λ. This would allow you to determine the time duration within an interval section by section and then add this to the previous ones to obtain the age of the respective layer. However, this would require a constant thickness per year for each interval. However, since this is most likely not the case, my next consideration was that the age must be the integral of a 1/λ(z) function, which I cannot model.
