General Question Regarding Internal Energy
In a closed system at equilibrium, internal energy is a function of temperature and volume due to the contributions of kinetic and potential energies of particles. The internal energy comprises the sum of each particle's energies, where potential energy depends on particle distances and kinetic energy includes translational, rotational, and vibrational components. The equipartition theorem explains that average energies are linked, with translational kinetic energy determining temperature. As such, the average potential energy is influenced by the system's volume. Understanding these relationships clarifies the statement from the textbook regarding internal energy.
jtabije
Hi all!
I have a quick question. In my Physical Chemistry textbook, the author states,
"For a closed system in equilibrium, the internal energy (and any other state function) can be expressed as a function of temperature and volume."
Can anyone explain just how that is true? I'm quite certain I'm overlooking something fundamental here.
All the best,
JT
An interesting question. Here are my thoughts at least on the internal energy part:
If you generalize a system to consist of n particles, the internal energy of that system is the sum of the kinetic and potential energies of each particle. The potential energy of each particle is a function of the distance of that particle from other particles. The kinetic energy of each particle is the sum of each particle's translational, rotational, and vibrational energies.
If the system is in thermodynamic equilibrium, the average rotational kinetic energy and average vibrational energy are functions of the translational kinetic energy (this is the basis for the equipartition theory). And the average translational kinetic energy determines the temperature. Also, in thermodynamic equilibrium the average potential energy of the particles is determined by the average distance between particles, which is obviously a function of total volume.
AM
Woah, AM. I've never heard of the equipartition theorem before, but after reading about it, what you said about internal energy makes complete sense. Like I said, I overlooked something fundamental.
Thanks!
Thread 'Question about pressure of a liquid'
I am looking at pressure in liquids and I am testing my idea. The vertical tube is 100m, the contraption is filled with water. The vertical tube is very thin(maybe 1mm^2 cross section). The area of the base is ~100m^2. Will he top half be launched in the air if suddenly it cracked?- assuming its light enough. I want to test my idea that if I had a thin long ruber tube that I lifted up, then the pressure at "red lines" will be high and that the $force = pressure * area$ would be massive...
I feel it should be solvable we just need to find a perfect pattern, and there will be a general pattern since the forces acting are based on a single function, so..... you can't actually say it is unsolvable right? Cause imaging 3 bodies actually existed somwhere in this universe then nature isn't gonna wait till we predict it! And yea I have checked in many places that tiny changes cause large changes so it becomes chaos........ but still I just can't accept that it is impossible to solve...
