General Solution for ODE: y'' + 6y' + 9y = x*exp(-3x)3x
itsjared
Im having trouble with this question. can anyone explain please?
Find the general solution.
Well, the general solution is the sum of the homogeneous solution and a particular solution.
The homogeneous solution (gotten from putting the right hand side = 0) is obtained using the characteristic equation.
To find a particular solution, one can make a clever guess how the solution must look like. Since the right hand side has a part e^{-3x} one can safely assume that also y must have this part. To deal with the x one can guess that the solution must contain a polynomial of some degree. Thus, a clever guess would be y=p(x)e^{-3x}. All that is left is to see which p(x) that will satisfy the solution.
thanks for the reply.
im working through this question. I am not to sure I am doing it right though.
K^2+6K+9 = 0
therefore K= -3
and y= A*exp(-3x) + Bx*exp(-3x)
y'=-3A*exp(-3x) - 3Bx*exp(-3x) + B*exp(-3x)
y(p)= Ax*exp(-3x)
y'(p)= A*exp(-3x) - 3Ax*exp(-3x)
am i on the right track?
The homogeneous solution looks correct, although you do not have to differentiate it. You merely have to add the solutions together in the end, y=y_H+y_{P}, so you are done with y_H.
In the particular solution you have assumed that the polynomial is p(x)=Ax, which is not the general case. In fact, a polynomial of larger order is needed. I think it is easier if you treat p(x) as a general polynomial, and then you will get an expression for the polynomial in the end, when you have put in y=p(x)e^{-3x} in the differential equation.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
