General solution to 2nd order DE
5 replies · 3K views · last reply
Dissonance in E
Hi, I am just looking for clarification whether or not I am doing these problems correctly, here's an example:
Find the general solution to
x'' -2x' + 5x = 0
Charasteristic polynomial.
Quadratic equation.
General solution form for complex roots.
form the char polynomial:
m^2 -2m +5 = 0
Solve for roots:
(-2 (+-)SQRT(2^2 - 4(1)(5)))/2
-1+SQRT(-16)
-1-SQRT(-16)
m1 = -1+4i
m2 = -1-4i
Insert into general solution form:
y = (e^ax)(Acoswx + Bsinwx)
y = (e^-1x)(Acos4ix + Bsin4ix)
General solution: (?)
y = (e^-x)(Acos4ix + Bsin4ix)
x'' -2x' + 5x = 0
Quadratic equation.
m^2 -2m +5 = 0
Solve for roots:
-1+SQRT(-16)
-1-SQRT(-16)
m1 = -1+4i
m2 = -1-4i
Almost!
Your general solution is
y = e-x(Acos(4x) + Bsin(4x))
You can verify that this is the solution by calculating y' and y'' and substituting them into your differential equation.
What do I do if I am asked to write a solution that satisfies the conditions
x(0) = 1
x´(0) =0
Your solution is actually x(t) = e-t(Acos(4t) + Bsin(4t)). I hadn't noticed earlier that you had switched your solution to be y as a function of x.
Use your initial conditions to substitute x = 1 and t = 0 into your solution, and x' = 0 and t = 1 into the derivative of your solution. That will give you two equations in two unknowns, so you should be able to solve for the constants A and B.
