Are Generalized Coordinates Necessary for Simplifying Complex Systems?
Generalized coordinates in Lagrangian mechanics can be viewed as a way to work with manifolds, particularly in simplifying complex systems like a double-pendulum. By recognizing the system's invariants, the degrees of freedom can be reduced from six in R^6 to a two-dimensional submanifold defined by the angles of the pendulums. In Hamiltonian mechanics, both coordinates and momenta are used to describe points in phase space, with Poisson brackets facilitating the evolution of functions over time. The discussion emphasizes the importance of understanding constraints and invariants when applying generalized coordinates. Overall, generalized coordinates are essential for effectively modeling and simplifying complex mechanical systems.
Tac-Tics
Are generalized coordinates, as used in Legrangian mechanics, just a different name for coordinates on a chart in a manifold? The idea of generalized coordinates never quite "clicked" with me, but after reading a paper today, it seems that they are just an implicit way of working with manifolds.
So, say you're working with a double-pendulumn system. You have two objects (the ends of the pendulumns) in 3D space, for a total of 6 degrees of freedom, so the entire system can be modeled in R^6. But, to simplify the math, we can use our knowledge of the system's invariants to reduce this down to a 2D submanifold, parametrized by the angle of each pendulumn as each swings in a plane.
Am I correct in coming to this conclusion?
Mathematics news on Phys.org
Yes, the coordinates are on a manifold referred to as "configuration space". The system trajectory is a curve in configuration space parametrized by the variable 't' (time).
In Hamiltonian mechanics, you have not just N coordinates, but also N momenta. These 2N components label points in "phase space". Phase space has some nice properties that come about due to the invariance of Poisson brackets with respect to different canonical sets of variables. A canonical transformation is a particular kind of coordinate transformation on phase space, called a "symplectomorphism". The Hamiltonian itself can be considered the generator (via Poisson brackets) of a one-parameter continuous family of symplectomorphisms (where the parameter is again time) that describes the system evolution. Also some other neat things come about, like Liouville's theorem, which is important for statistical mechanics.
I'm glad to see I'm on track with my intuition.
You used a lot of big words I don't know there. What is a Poisson bracket? Wikipedia goes on to talk about symplectic manifolds, which I am also unfamiliar with. (Wikipedia is a big believer in defining big words in terms of even bigger words in math and physics articles).
If the coordinates are q_i and their corresponding canonical momenta are p_i, then the Poisson bracket of two functions f(q,p), g(q,p) is given by
\{f, g\}_{PB} = \sum_i \frac{\partial f}{\partial q_i} \frac{\partial g}{\partial p_i} - \sum_i \frac{\partial f}{\partial p_i} \frac{\partial g}{\partial q_i}
Then, the time evolution of any given function \phi(q, p, t) is given by
\frac{d\phi}{dt} = \frac{\partial \phi}{\partial t} + \{\phi, H\}_{PB}
where H is the Hamiltonian.
It will be easiest to understand if you apply it to a simple one-dimensional system that you know already, like a harmonic oscillator or something. Just walk through the steps and see what happens.
To be precise, we use our knowledge of the system's invariants/constraints to show that coordinates lie on a 2D manifold that can be parameterised with two independent coordinates. The 6 coordinates could also be used as generalized coordinates if the corresponding constraint terms are included in the Lagrangian.
Many systems cannot be described fully by independent coordinates, e.g. rolling sphere.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
