Why Does Changing Wire Gauge Affect Voltage and Current in a Generator?
The discussion centers on the effects of wire gauge on voltage and current output in a small generator setup. The user reports obtaining 50 volts at 1 amp with 28-gauge copper enameled wire, but only 15 volts at 0.25 amps when switching to 24-gauge wire. Key insights indicate that no-load output voltage should remain relatively constant regardless of wire gauge, while increased wire diameter can lead to lower resistance and potentially fewer turns in the winding, affecting overall output. Additionally, factors such as leakage inductance, number of turns, rotational speed, and magnet strength are critical in determining generator performance.
  • Understanding of generator design principles
  • Knowledge of wire gauge effects on electrical resistance
  • Familiarity with voltage, current, and power relationships
  • Basic concepts of electromagnetic induction
  • Investigate the impact of wire gauge on generator efficiency
  • Learn about calculating turns per coil in generator windings
  • Explore the effects of leakage inductance on generator performance
  • Study the relationship between rotational speed and output voltage in generators
Electronics hobbyists, electrical engineers, and anyone involved in generator design and optimization will benefit from this discussion.
NY Operations Tech
TL;DR
Generator wiring question
I am building a small generator. 12 - 5/8″ magnets rotating around 9 - 3/4″ diameter, 28-gauge copper enameled wire. Not under load, I am getting 50 volts at 1 amp. But when I increase the wire size to 24-gauge, I am getting 15 volts at .25 amps. I thought amps go up when volts go down.
NY Operations Tech said:
TL;DR Summary: Generator wiring question
Not under load with 50 volts at one amp makes no sense. If it not under load then there is no current. 0 amps.
Without a clear description of the two different designs, we cannot help you. A clear description includes at least one diagram that clearly shows the entire generator, including the winding design.
As has been mentioned, "no-load" means no output current.
The no-load output voltage should be independent of the gauge of the wire, to a first approximation. Can you make those two measurements?
(As you increase the size of the wire, leakage inductance will generally go up, so you may get a small decrease in the no-load output voltage.)
If all you are doing is increasing the diameter of the wire, you should see an increase in output current capability because the parasitic resistance of the windings is lower.
For the same amount of power, Yes.
For the same power, the product of Volts and Amps is the same.
Have you counted the number of turns with each wire size? Are they the same?
Larger wire may mean fewer turns, especially if in the same space.
Also, no-load output voltage is directly dependent not only on number of turns but also on rotational speed and magnet strength.
There could be some shorted turns in the 24ga. winding.
Cheers,
Tom
  • · Replies 28 ·
17K
