Geodesics: Constant Velocity & Affine Parameterization
  • Thread starter Thread starter latentcorpse
    Geodesics Homework
latentcorpse
Affinely parameterised geodesics satisfy \nabla_XX=0
Why does this mean they have constant velocity?
Thanks.
If we parametrize the geodesic by \lambda then the velocity is given by \frac{dX^a(\lambda)}{d\lambda}=\dot{X}^a
Thus, \nabla_{\lambda}\dot{X}^a=\dot{X}^b\nabla_{b}\dot{X}^a=\dot{X}^b\left(\partial_b \dot{X}^a+\Gamma_{bc}^a \dot{X}^c\right)=\ddot{X}^a+\Gamma_{bc}^a\dot{X}^b\dot{X}^c=0 since it is the geodesic equation. Therefore the velocity is constant along the geodesic.
To solve this, I first used the units to work out that a= m* a/m, i.e. t=z/λ. This would allow you to determine the time duration within an interval section by section and then add this to the previous ones to obtain the age of the respective layer. However, this would require a constant thickness per year for each interval. However, since this is most likely not the case, my next consideration was that the age must be the integral of a 1/λ(z) function, which I cannot model.
