Geometric description of a kernel
  • Thread starter Thread starter eyehategod
    Geometric Kernel
eyehategod
let T:R^{3} \rightarrow R^{3} be a linear transformation.
how can i figure out a geometric description of the kernel and range of T. What do I have to look at?
That's pretty vague. Thinking about dimensions would be a good start.
For a general linear transformation, about the most you can say are that the kernel and range are both subspaces (if they are not trivial). For different the kernel might be {(0,0,0)}, a line through (0,0,0), a plane through (0,0,0), or all of R3. Same for the range.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
