Geometric Series: 2/3^k and -2/10^k
Kyousik
(infinity)sigma(k = 0) [2(2/6)^k + (-2/10)^k)
Geometric Series
I split these up into two geometric series
(infinity)sigma(k = 0) [2(1/3)^k]
2 / (1 - 1/3)
r = 3
This diverges.
(infinity)sigma(k = 0) (-1/5)^k
1 / (1 + 1/5)
r = 5/6
This converges.
Now, I'm not sure what to do? If it does converge, I need to find its sum o_O.
The first series doesn't diverge. What makes you think it does?
Oh oops! I see, the |r| value is the ratio. Not the number you get after. The number you get after is what the series converges to?
So 3 + 5/6 = 18 / 6 + 5 /6 --> 23 / 6
Would that be correct?
Yea. Although to be more rigorous, you need to show those two series converge absolutely to justify splitting the sum. This is only a problem for the second one, which is an alternating series, but taking the absolute value of each series gives another converging series, so you're ok.
This might sound like a technicality, and it is, but there are examples where your method would give a wrong answer. For example, it wouldn't work on the series:
\sum_{n=1}^\infty ((-1)^n+(-1)^{n+1})
There are also examples where it would give you a finite answer, but which would be wrong. These are rare, and I can't think of one off hand, but I'll post one if I do.
So to prove that, I would use the ratio test to show absolute convergence? Absolute convergence was very confusing reading from the textbook.
I forgot there were other ways to show absolute convergence. Like using harmonic, or comparison or something.
A series \sum a_n converges absolutely iff \sum |a_n| converges. If the series is already positive, like the first one, you're done. Since the second isn't, you need to show that by taking the absolute value, which just amounts to changing -1/5 to 1/5, you still get a series that converges.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
