Uncovering the Mystery Behind Football Field Math Facts
The discussion focuses on understanding a mathematical fact related to football fields, specifically the application of Pythagoras' Theorem. The confusion arises from calculating the hypotenuse of a right triangle, where the base is 180 feet and the hypotenuse is stated as 180.5 feet due to an additional foot added to the rope's length. Clarification is provided that the correct hypotenuse is derived from the triangle's dimensions, emphasizing that the angle is not 45 degrees, which led to miscalculations. Participants highlight the importance of correctly interpreting the problem statement to arrive at the right conclusions. Overall, the thread illustrates the challenges of grasping mathematical concepts and the need for precise understanding of the problem's parameters.
Chrono
I was just messing around and ran across this site that hate math facts on it and I chose a random one about a football field. Here's a http://www.math.hmc.edu/funfacts/ffiles/10010.2.shtml# the fact.
Now, I understand what they're trying to get it, but what I don't get is how they came up with it. How did they get the answer using the square root of (180.52 - 1802), and where did they get that from?
Mathematics news on Phys.org
It's a straightforward application of Pythagoras' Theorem. Divided the triangle into two equal parts each of which is a right triangle. Each base is 180 feet (60 yards = 120 yards / 2) and the hypotenuse is 180.5 feet (the 1 foot extension is shared equally by both triangles).
I'm still not getting 180.5 as the hypotenuse. This should be easy, I don't know what I'm doing wrong. Here's what I did. I put 180 as the base of the right triangle, so I had Cos[45] = 180 / hypotenuse. Then, I did the algebra and got hypotenuse = 180 / Cos[45] which gave me 254.5. What'd I miss here?
In the statement of the problem you were told that 1 foot was added to the length of the rope. The rope starts off at 120 yards = 360 feet so it ends up being 361 feet long half of which is 180.5 feet. So the hypotenuse IS 180.5 feet long and the base of the right triangle is 180 feet from which you can calculate the HEIGHT of the triangle using Pythagoras.
You also led yourself astray ASSUMING the angle is 45 degrees - it's not!
Freudian slip: I suspect that "have math facts" became "hate math facts" tells us a little about why Chrono couldn't understand it!
Halls,
You forgot the smiley at the end of your "observation!" :-)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
