Geometry of IPM/double winding layer with Ansoft Rmprt
Assistance is requested for creating a double layer 36 slot IPM motor using Ansoft/Rmprt software, specifically for schoolwork. The user has successfully created a single layer model but is new to Ansoft. There is a need for clarification on the application and previous modeling efforts to provide effective guidance. The discussion suggests that the thread may be moved to the Homework Help section due to its academic nature. Further input from the user is necessary to receive tailored tutorial suggestions.
Omokhafe
Please I need help on how to creat double layer 36 slot IPM Motor using Ansoft/Rmprt software.
Welcome to the PF.
What is the application? Is this for schoolwork? What have you done so far? What other models have you created so far with ANSOFT?
Welcome to the PF.
Yes for school work. I want to design IPM machie using double layer winding
I was able to create single layer.
am new in using Ansoft.
Since it is schoolwork this thread may get moved to the Homework Help section of the PF.
For now, you need to show us your efforts, before we can offer tutorial suggestions. :smile:
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
Thread 'How Does Jaguar's 1980s V12 Dual Coil Ignition System Enhance Spark Strength?'
I have come across a dual coil ignition system as used by Jaguar on their V12 in the 1980's. It uses two ignition coils with their primary windings wired in parallel. The primary coil has its secondary winding wired to the distributor and then to the spark plugs as is standard practice. However, the auxiliary coil has it secondary winding output sealed off. The purpose of the system was to provide a stronger spark to the plugs, always a difficult task with the very short dwell time of a...
