Getting Power Function given points.
To create an equation from four given points that appear to represent a decaying function, one approach is to consider fitting a polynomial of varying degrees or exploring exponential functions. A suggested functional form is a power function, specifically y = ab^x, which aligns with the notion of decay. By using two of the points, two equations can be established to solve for the constants a and b. This method allows for a best-fit analysis based on the selected function. Ultimately, choosing the right model is key to accurately representing the data.
krnhseya
I have 4 points (x and y values) and I was wondering how I can make an equation out of it.
It looks like a decaying function.
n/a
n/a
I absolutely have no idea how to approach this...Sorry.
That's quite an open-ended problem you've got there. You could fit polynomials of degrees 1, 2, 3, or 4 to your data set. And who says it has to be a polynomial? Why not an exponential? My advice would be to pick some functional form, and then try to make a best fit.
Since you refer to a "power function" and "decaying function" I would guess that you are looking for a function of the for y= abx. Two values of (x,y) will give two equations to solve for a and b.
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
