Given Power, Weight, and Vmax find Vmax at angle θ
The discussion revolves around calculating a car's maximum speed on a 1 in 20 incline, given its weight and power output. The initial calculations involve determining the force using the formula P=FV and finding the angle θ using sin θ = 1/20. However, a key point raised is the potential confusion between sine and tangent in incline calculations, suggesting that tan θ might be more appropriate. Additionally, it is noted that the resistive force due to friction should remain constant, implying that the same frictional force from the level road should be used instead of recalculating it for the incline. This insight indicates that the initial approach to the problem may need adjustment to arrive at the correct maximum speed.
Jack_Straw
A car of weight 1490 N operating at a rate of 121 kW develops a maximum speed of 49 m/s on a level, horizontal road.
Assuming that the resistive force (due to friction and air resistance) remains constant, what is the car’s maximum speed on an incline of 1 in 20; i.e., if θ is the angle of the incline with the horizontal, sin θ = 1/20? Answer in units of m/s.
P=FV
find force:
force=power/velocity
F=121,000/49
find θ:
θ=sin-1(1/20)
find F at angle θ:
Fθ=(121,000/49)/cos(sin-1(1/20))=2472.48N
find FN at angle θ:
F=(1490N)(sin(sin-1(1/20)=74.5N
find Fnetθ:
Fnetθ=Fθ-F=2472.48N-74.5N=2397.98
insert Fnetθ into V=W/F:
V=121,000/2397.98=50.46m/s
This answer is reported as wrong. Any ideas? Thanks
Is the "sin θ = 1/20" actually given to you, or is that your own relation? I ask because typically incline grades (of the form "one part in some other part") are specified in rise/run. If so, that means tanθ = 1/20, not sine.
It turns out that it doesn't really matter too much, since tanθ ≈ sinθ for small θ, and θ is pretty small here. But, I thought I should mention it.
P=FV
find force:
F=121,000/49
find θ:
θ=sin-1(1/20)
find F at angle θ:
I'm not sure I follow what the purpose of this Fθ is. The problem statement says "Assuming that the resistive force (due to friction and air resistance) remains constant..." That tells me that you don't need to calculate a new frictional force. Just use the same frictional force as before.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
