GR explanation of Newtonian Phenomena
aachenmann
1. How would a general relativist explain why an object falls towards the earth?
2. Is it correct to say that it is not the apple that falls towards the Earth but it is the Earth that accelerates towards the apple? Why is this ok to say?
The apple follows a geodesic path through space-time. One way o describing the mathematical characteristics of this path is to say that it satisfies the principle of extremal aging.
see for instance http://www.bun.kyoto-u.ac.jp/~suchii/extrem.aging.html
http://www.eftaylor.com/pub/chapter2.pdf
and look for past PF posts with this keyword.
2) The question is really irrelevant in GR - it doesn't matter which viewpoint you use.
Science does not explain, it describes. To say that it explains leads one into a logical circle.
What accelerates is actually doing the acceleration is a coordinate dependant statement. Once you choose a coordinate system you can state whose coordinates in that system represents an accelerating object. Here I speak of 3-acceleration since the 4-acceleration of each object, i.e. Earth and apple, is zero.
Pete
Since the OP is no longer with us, there seems no point in keeping this thread open.
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
