Grad. School in Physics w/ BA in Romance language
Applying to a physics graduate program with a BA in Romance Languages from NYU presents significant challenges. Most programs require an undergraduate degree in physics or a closely related field, such as engineering physics or physical chemistry. While some schools might consider applicants with different backgrounds, this is rare and typically reserved for exceptional candidates. The GRE is generally required by many institutions in the U.S., but it cannot substitute for the necessary physics coursework. Prospective students without a physics background will likely need to return to undergraduate studies for two to three years to complete the required prerequisites. Independent study in physics may be beneficial, but it is unlikely to compensate for a lack of formal education in the field.
chinablue
How would one apply to a physics graduate program when they have a BA in Romance Languages from NYU?
Are prerequisites specific to each school?
I assume a GRE is required for all schools.
Does one need an undergraduate degree in Physics?
Any advice along these lines is greatly appreciated.
An undergraduate degree in physics is a prerequisite for most undergraduate programs. Some people are accepted with degrees that are close such as engineering physics or physical chemistry or hybrid degrees.
Given that a BA in romance languages has little if any overlap with a standard undergraduate physics curriculum, the only way to get into physics graduate school is to return to undergraduate study for a few years and earn a second degree.
The GRE is not required for all schools, but it is for most in the USA. And for what it's worth, it's not a substitute for an undergraduate degree. It's more of a means of partially compensating for the different levels of rigor and difficulty at the many different schools out there.
Nominally they say you will need a STEM undergraduate degree...but I suppose for an outstanding applicant they might consider other degrees. I have heard anecdotes of people who got into PhD programs without even having done an undergrad. These would be extreme snowflake superstar cases, though.
Now, as to whether you are an outstanding applicant. Most likely your undergrad did not require you to do any physics at all, and if you did do it, it was for an elective.
I don't know your background...have you ever taken any physics courses?
Yeah, that won't work at all. They won't accept you and you'd be a world of hurt if they did. (unless you have maybe done some major level of independent study on the side and have a particular major genius for physics in some out of the ordinary way) Almost certainly you'll need to go back to undergrad for a few years (probably 2 or 3, unless there is a lot you've left out of your story and you've already taken a considerable number, but perhaps just shy of a dual major or something).
Bit Britain-specific but I was wondering, what's the best path to take for A-Levels out of the following (I know Y10 seems a bit early to be thinking about A-levels, but my choice will impact what I do this year/ in y11) I (almost) definitely want to do physics at University - so keep that in mind... The subjects that I'm almost definitely going to take are Maths, Further Maths and Physics, and I'm taking a fast track programme which means that I'll be taking AS computer science at the end...
After a year of thought, I decided to adjust my ratio for applying the US/EU(+UK) schools. I mostly focused on the US schools before, but things are getting complex and I found out that Europe is also a good place to study. I found some institutes that have professors with similar interests. But gaining the information is much harder than US schools (like you have to contact professors in advance etc). For your information, I have B.S. in engineering (low GPA: 3.2/4.0) in Asia - one SCI...
I'm going to make this one quick since I have little time. Background: Throughout my life I have always done good in Math. I almost always received 90%+, and received easily upwards of 95% when I took normal-level HS Math courses. When I took Grade 9 "De-Streamed" Math (All students must take "De-Streamed" in Canada), I initially had 98% until I got very sick and my mark had dropped to 95%. The Physics teachers and Math teachers talked about me as if I were some sort of genius. Then, an...
