Graph of time vs distance for sizing a motor for linear motion
When sizing a motor for linear motion with a short stroke of 0.5 mm and a cycle time of 0.05 seconds, the graph of time versus distance will reflect the need for precise control within a feedback loop. Calculating the required acceleration involves using the formula Distance = 0.5 * a * t^2, leading to an acceleration of 0.8 m/s² for optimal performance. The motion profile should be designed to ensure that the motor stops within the specified position tolerance, and if oscillation occurs, adjustments may be necessary. Understanding the integration of acceleration and velocity is crucial for motion control, especially when dealing with finite jerk profiles to minimize positioning errors. Diagrams can aid in visualizing these concepts, particularly in complex engineering environments.
Travis T
Hi, I'm sizing motor for a linear motion,
usually for the time distance graph would be looks like this,
however, how does the graph look like if the stroke is very short?
Example: velocity is 0.1m/s, acceleration is 1m/s2, moving stroke is 0.5mm, a cycle is within 0.05s
the application is to compensate positioning errors which is very small.
Travis T said:
... the application is to compensate positioning errors which is very small.
The motor is inside a feedback loop, so the inertia of the motor, and the characteristics of the feedback loop will be very important to the performance.
Travis T said:
... however, how does the graph look like if the stroke is very short?
You might consider using a piezo transducer to make the fine position correction.
I like to solve servo motion problems by making a simple hand sketch showing acceleration, velocity, and position. You want to move 0.5 mm in 0.05 seconds as precisely as practical. Start the calculations by assuming a constant acceleration move, as shown in the simple sketch below:
Since ##Distance = 0.5 * a * t^2##, and we know both the distance and the time, we can solve for the acceleration and add that number to the sketch. This is a minimum acceleration move, which is a good place to start when you want precision or a fast move. The peak velocity is then ##0.8 m/s^2 * 0.025 s = 0.02 m/s##. If the acceleration and peak velocity are within the servo specifications, then program that move, and check the response. Does it do what you want?
If it stops within your position tolerance, you are finished. If it oscillates to a stop, the next step is a finite jerk move. If that happens, post again and we can help you solve that problem.
Likes Travis T and DeBangis21
Is it Distance = 0.25 * a * t^2? instead of 0.5?
how do we get 0.8m/s^2?
Velocity is the integral of acceleration, or the area under the acceleration curve.
Similarly, position is the integral of velocity, or the area under the velocity curve.
Since the acceleration curve has a discontinuity, the integration is in two parts. The first part is from 0 to 0.025 seconds, the second part from 0.025 seconds to 0.05 seconds. The two parts are then summed to get the final velocity, which is zero. The curves help show that the acceleration is positive for halfway, and negative for the last halfway. The integral of the acceleration is the velocity, which increases to a maximum at the halfway point, then decreases to zero at the end.
It is important understand these concepts when doing motion control, and the diagrams help to understand the concepts. The diagrams are not very important for simple problems like this. They become much more important if you need, for example, a finite jerk motion profile to reduce position errors. The diagrams are also useful in a large engineering department to communicate to other engineers.
We get ##0.8 m/s^2## by solving ##Distance = 0.5at^2## as follows:
Distance = 0.25 mm (halfway to 0.5 mm) (distance from beginning to first discontinuity)
t = 0.025 second (halfway to 0.05 second) (time from beginning to first discontinuity)
The only unknown is the acceleration, so solve the equation for the acceleration.
Thanks for the clear explanation.
Likes berkeman and Tom.G
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
