Graph of velocity against radius?
The discussion focuses on a physics assignment involving the graphing of velocity against the inverse of radius (1/r) to determine the mass of a planet. The method involves calculating the gradient of the graph to find the time taken to travel between two radius points, which is then used to derive acceleration due to gravity. The relationship between acceleration, gravitational constant (G), and radius allows for the calculation of the planet's mass using the formula g = Gm/r². This approach provides a systematic way to approximate the mass based on multiple data points.
  • Understanding of gravitational physics and equations of motion
  • Familiarity with graphing techniques, specifically plotting velocity against 1/r
  • Knowledge of the gravitational constant (G) and its application
  • Ability to perform calculations involving acceleration and mass
  • Study the equations of motion in detail, focusing on acceleration calculations
  • Learn how to graph inverse relationships, specifically velocity vs. 1/r
  • Research the gravitational constant (G) and its significance in astrophysics
  • Explore methods for estimating mass from gravitational data in celestial mechanics
Students in physics, particularly those tackling assignments related to gravitational forces and celestial mechanics, as well as educators looking for practical examples of applying physics concepts in problem-solving.
pconstantino
Hello, we been set a physics assignment where we are given a table of data, a spaceship approaches a planet, and the velocity and radius are given at certain points, we have to graph velocity against 1/r and hence find the mass of the planet.
I really don't get this question, i tried slope and area under graph but can't reach a conclusion.
Any help please?
There are two ways to go about this, the first is to use the graph (green - the one I think you need) the second is without (red). The final section (blue) is completed regardless of which initial method (green or red) you choose:Because the graph is 1/r, working out the gradient between two radius points will give you the time it took to travel between them. (Units on the graph will be m/s and 1/m so they solve to leave s.)
Once you have this, using the equations of motion you can work out acceleration = a = (VA-VB)/t.
This acceleration (assuming the rocket engines are off) is gravity between the two points.If you know the velocity at point A (VA) radius A (rA) and the velocity at Point B (VA) radius B (rB) you can work out the acceleration between those two points.
Using the equations of motion you know: initial velocity = VA, final velocity = VB and distance = rA-rB.
Plug in those values and you'll get the acceleration between the two points.
That acceleration (assuming the rocket engines are off) will be the gravity value between those two points.You repeat this between each set of coordinates to gain various g values.
Now, g = Gm/r2.
Where G is the gravitational constant and you know your r values along with g from above. Leaving you to rearrange and solve for m which is the mass of the planet.
Hopefully, they should all be within an acceptable range of each other to give you an approximate mass.
wow, amazing, this helps a lot, thank you so much my friend.
