Verifying Solution for cos^4 x in Terms of cos 4x & cos 2x
  • Thread starter Thread starter Chewy0087
    Cos Terms
The discussion focuses on expressing cos^4 x in terms of cos 4x and cos 2x, starting from the identity cos^2 x = 0.5(1 + cos 2x). An initial attempt yielded the expression cos^4 x = 0.25 + (cos 2x)/2 + (cos 4x + 1)/8, which was checked against Wolfram Alpha. Participants confirmed that the expression can be simplified further, leading to the correct form of cos^4 x = 3/8 + (cos 2x)/2 + (cos 4x)/8. Graphing the function was suggested as a method to verify the correctness of the derived expression. The conversation concludes with a consensus on the correct formulation of cos^4 x.
Chewy0087
express cos^4 x in terms of cos 4x and cos 2x given that
cos^ x = 0.5(1 + cos 2x)
i did some playing around for a minute and came to this;
cos^4 x = 0.25 + (cos2x)/2 + (cos 4x +1)/8
and thought, great! now i'll just check it on wolfram however i got this;
http://www.wolframalpha.com/input/?i=y+=0.25+++(cos2x)/2+++(cos+4x++1)/8
as opposed to
http://www.wolframalpha.com/input/?i=cos+^4+x
now, just looking at the graphs it seems okay however none of the alternate forms or expansions are the same, i would love it if someone could just verify that I'm right it's quite an important question!
thanks again
your answer is correct
if you group everything over a common denominator it might become more apparent
thanks a lot for that, it was really bugging me :D
You can always try to graph as a way to check your work:
y = \cos ^ 4 x - \left( 0.25 + \frac{\cos (2x)}{2} + \frac{\cos(4x) + 1}{8} \right)
to see if it turns out to be the x axis. If it does, then, everything should be fine. :)
Btw, your expression can be further simplified to:
\cos ^ 4 x = {\color{red}\frac{5}{8}} + \frac{\cos (2x)}{2} + \frac{\cos(4x)}{8}
I got
\cos ^ 4 x = {\color{red}\frac{3}{8}} + \frac{\cos (2x)}{2} + \frac{\cos(4x)}{8}
that's a good idea actually, thanks
i'm sure he meant 3/8
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
