Graphing Functions of Differentiation
frosty8688
Find the intervals of increase or decrease.
h(x)=(x+1)^{5}-5x-2
I found the derivative to be
\begin{align*}
h'(x) &= 5(x+1)^{4}-5 \\
&= 5[(x+1)^{4}-1] \\
&= (x^{4}+4x^{3}+6x^{2}+4x+1-1) \\
&= (x^{4}+4x^{3}+6x^{2}+4x) \\
&= x(x^{3}+4x^{2}+6x+4) \\
&= x[x^{2}(x+4)+2(3x+2)]
\end{align*} That is what I got so far.
If your goal is to find out where ##h## is increasing or decreasing, then your first expression for ##h'(x)## is probably easier to work with than the rest of the stuff you wrote. For what values of ##x## is the following inequality true?
$$5(x+1)^4 - 5 >0$$
When x > 0 and when x < -2.
Please explain how you got this answer.
When x is greater than 0, the first part of the equation is greater than 5. Let's say you put in 1 for x and 5*2 - 5 = 5 which is greater than 0. Also, when x is less than -2, let's use -3, then -2^4 = 16 and 5*16= 80 and 80-5= 75, so x is greater than 0.
It seems like you are just plugging in values for ##x##, as opposed to solving the inequality. A more careful line of argument might start as follows:
Observe that
$$5(x+1)^4 - 5 > 0$$
if and only if
$$5(x+1)^4 > 5$$
if and only if
$$(x+1)^4 > 1$$
If we put ##y = x+1## then this is equivalent to
$$y^4 > 1$$
Since the equation ##y^4 = 1## has exactly two real solutions (##y = \pm 1##), it follows that the equation ##(x+1)^4 = 1## has exactly two real solutions (##x = 0, -2##).
Now how can we use this to obtain the desired conclusion?
The book has 0 and -2 as critical values.
Thanks, I edited my previous post to fix the sign error. So what can you say about the sign of ##h'(x)## in each of the following intervals: ##(-\infty, -2)##, ##(-2, 0)##, ##(0, \infty)##?
It is increasing on (-∞,-2) and (0,∞) and decreasing on (-2,0) because x is greater than 0 on the intervals (-∞,-2) and (0,∞) and less than 0 on (-2,0).
The derivative in this case is continuous. Once you have found the "critical points", where the derivative is 0, the derivative can change from "+" to "-" only where it is 0 so "plugging in values of x" in each interval is a perfectly valid way of solving the inequality.
I found that to be easier, because I still couldn't find out from the derivative how -2 was a critical number.
What's the value of the derivative when x = -2?
The answer is 0.
