Gravel Running: Friction & Velocity Questions
  • Context: High School
  • Thread starter Thread starter danielandpenn
    Running
The discussion revolves around the relationship between friction and velocity while running on different surfaces, specifically comparing gravel to dry pavement. Participants explore concepts related to traction, energy transfer, and resistance forces in the context of running and cycling on varying terrains.
  • One participant questions why reduced friction on gravel does not lead to increased speed, suggesting a connection between friction and energy transfer during running.
  • Another participant agrees that gravel creates more opposition to motion due to the need for wheels or feet to displace gravel stones, which slows progress.
  • It is proposed that friction is necessary for effective energy transfer from the foot to forward motion, and low friction can lead to wasted energy as the foot may slide rather than push off effectively.
  • A participant explains that friction acts as a shear force, necessary for traction, and distinguishes between static and dynamic friction in the context of running and cycling.
  • One participant introduces the idea that while lower friction can reduce resistance, it also decreases the tractive force needed to initiate motion, complicating the relationship between friction and speed.
  • Rolling resistance is discussed as a separate issue, with a participant noting that displacement of gravel requires more energy, but at higher speeds, stability may improve as the bike begins to plane over the surface.
Participants express multiple competing views regarding the role of friction in motion on gravel versus pavement. There is no consensus on the relationship between friction, traction, and speed, as different aspects of the discussion highlight varying interpretations and conditions.
Some limitations include the dependence on definitions of friction types, the complexity of energy transfer in different scenarios, and the unresolved nature of how rolling resistance interacts with friction on various surfaces.
danielandpenn
Okay, so I was running the other day and thinking about friction as I hit a patch of gravel. I'm a new physics student so I know enough to think about some things but not enough to know the answers yet. Why is it that if friction works to slow down my velocity, then when there is less friction (ie...I hit the gravel as opposed to the dry pavement) why don't I go faster? I can't go faster on loose gravel...just trying to make a connection here. Thanks for your input!
Well, if I was cycling on a hard pavement and then went on to gravel, I don't think it would make my progress easier. The opposite, I would imagine. More opposition to my motion: slower speed. This is because the wheels dig into the gravel and have to move gravel stones out of the way in order to roll forward.
On the other hand, when trying to run on a surface, you need plenty of grip between your shoes and that surface. The gravel is not so helpful there either and would make it more difficult to run. This is because the gravel stones tend to slip and slide over each other.
Friction is required in transferring energy from your foot into your forward motion. When running on a surface with low enough friction, you begin to waste energy in this transfer because your foot spends some time sliding rather than staying planted. In this sense, a certain amount of friction is required to run, just as it is required for an object to roll down a hill. This is different from the role friction plays when sliding an object, which is the way friction is treated in most intro mechanics courses. In this case, friction gets in the way of sliding and slows down the object.
Friction is required to achieve 'traction', otherwise one's foot or bicycle's (motive) wheel, would slide or slip.
Similarly, in braking, one would slide, or otherwise have a reduced magntide of deceleration without friction.
Friction is a shear force, i.e. it acts parallel to a surface, rather than a normal force acting normally or perpendicularly to the surface. Pushing (normally) against an object does not require friction to work, but applying a shear force requires 'friction'.
The friction between a foot or wheel and the ground/surface is static, as opposed to sliding/dynamic friction.
In running or riding on gravel, the force from the foot or wheel would go into moving the gravel, either translationally or rotationally. There is friction between the foot/wheel and the gravel.
You are mixing the traction force with the resistance force. They are both the same but opposite. If you want to push a big rock, it is a lot easier on ice than on asphalt, because the friction force is less on ice than asphalt and its putting less resistance. But when you push the rock with your feet on ice, you also have less friction than on asphalt, so you also produce less tractive force.
When you rely on traction (hence friction) to initiate a motion, the higher the friction force, the the faster you can go. But if you rely on another form of force to initiate a motion (say the wind pushing a sail) the friction becomes an resisting force and the lower the friction force, the faster you can go.
Rolling resistance is related to the amount of deformation (deformation with hysteresis so that energy is consumed by the deformation and restoring of the tread orientation on a tire) and/or displacement involved, a separate issue than friction. When driving through gravel, you displace a lot of rocks, so it takes more energy. I've done this on motorcycle, on a gravel bed next to train tracks, and with sufficient speed you start to plane, similar to water or sand, reducing the rolling resistance, and making the bike more stable (it's a bit wobbly till you get up to speed).
  • · Replies 35 ·
  • · Replies 60 ·
  • · Replies 22 ·
