Calculating Gravitational Energy of 100 lb Mass in Rotation
In summary, the 100lb mass attached to a free spinning disk would generate a total of 1354 joules of energy.
Pinon1977
126
I have a 100 lb mass that is attached to a disk which is rotating freely about an axle. How do I calculate the gravitational energy contributed buy this 100 pound mass as it rotates from the 12 position to the six position
No clue maybe. M x g x h?
No clue
Depends on the orientation of the axle ... but otherwise you are correct. Pay attention to the units !
Pinon1977 said:
No clue
This is not acceptable, per PF rules. Using @BvU's help, your next post should be your attempt at a solution.
Likes BvU
Ok. My attempt would look like this:
KE = 100lbs x 9.8ms2 x 10ft = 1354J
But that is if the weight it's Free Falling, correct? This particular scenario involves the weight being attached to a disc that is 10 feet in diameter. The disc weighs approximately 100 pounds as well. So wouldn't those two variables be taken into consideration?
Pinon1977 said:
the gravitational energy contributed by this 100 pound mass
I should think not.
You still haven't told us about the orientation nor about the location of the axis of rotation :rolleyes:
My apologies. The 100lbs is permanently mounted on the disc 5 feet from the axel ( or at the outer edge of the disk). As the disc rotates, the orientation of the weight changes respectively (as the weight is hard mounted to the disc which is free spinning).
Yes that's a relevant but incomplete equation. M*g*h = ??
Ke = mgh. So, 100 pounds attached at the Outer Perimeter of a 10-foot diameter free Spinning Disk (which has a mass of 100 lb itself) would still be 100 times 9.8 times 10?
Watch your units. Is ##g## 9.81 thingies in your non-SI units ?
Pinon1977 said:
Ke = mgh.
Not KE. The change in Potential Energy (PE) = mgh
What BvU said about units. g is only 9.81 m/s/s if you are working in SI units..
Working in SI units the description becomes... "45kg attached to the outer perimeter of a 3 meter diameter spinning disc"
To rotate the disk so that the 45kg mass moves from the bottom/6 o'clock position to the top/12 o'clock position would require..
ΔPE = 45 * 9.81 * 3 = 1324 Joules
To rotate the disk so that the 45kg mass moves from the top/12 o'clock position to the bottom/6 o'clock position would require..
ΔPE = 45 * 9.81 * -3 = -1324 Joules
eg you get the same number of joules back again.
Note: We're assuming the 100lbs/45kg is all lumped together in one place on the perimeter not distributed around the perimeter of the disk.
1. How is gravitational energy of a 100 lb mass in rotation calculated?
The gravitational energy of a 100 lb mass in rotation can be calculated using the formula: E = mgh, where E is the energy in joules, m is the mass in kilograms, g is the acceleration due to gravity (9.8 m/s^2), and h is the height or distance from the center of rotation.
2. What is the unit of measurement for gravitational energy?
The unit of measurement for gravitational energy is joules (J).
3. How does the mass of the object affect its gravitational energy in rotation?
The mass of the object has a direct effect on its gravitational energy in rotation. The greater the mass, the greater the gravitational energy. This is because the formula for gravitational energy (E = mgh) includes the mass of the object.
4. Can the gravitational energy of an object in rotation be negative?
No, the gravitational energy of an object in rotation cannot be negative. The formula for gravitational energy (E = mgh) always yields a positive value, as both mass and height are positive quantities and acceleration due to gravity is a constant value.
5. How does the height or distance from the center of rotation affect gravitational energy?
The height or distance from the center of rotation has a direct effect on gravitational energy. The higher the object is from the center of rotation, the greater the gravitational energy. This is because the formula for gravitational energy (E = mgh) includes height as a variable.
