Where Is Zero Gravity Between Earth and Moon?
The discussion centers on identifying the point between Earth and the Moon where gravitational forces cancel each other out, resulting in zero weight for an object. It clarifies that the ratio of the Moon's gravity to Earth's gravity (1/6) does not directly translate to the distance from the Moon where this balance occurs. Instead, participants emphasize the need to use gravitational force equations to accurately determine this point. Ultimately, the calculated position for zero gravity is found to be 1/10 of the total distance from the center of the Moon. This highlights the importance of mathematical analysis in understanding gravitational interactions in space.
nilic1
Where on an imaginary gravitational field line between Earth and moon, a mass would have no weight neither due Earth nor due to moon?
If you mean when the gravitational force is zero, then you just need to equate
FEarth and FMoon for a mass m and solve for the distance.
Thanks for your reply. This was meant to be a straight forward answer without any calculation.
Since the gravity of the moon is 1/6 that of Earth , does it follow that the distance where there is no gravity on the object is 1/6 the distance between moon and Earth, starting off from the moon?
No, that 1/6 figure is only true about the surface gravity of the Earth vs. the surface gravity of the moon. It is not applicable everywhere in space.
I think you really do need to set up an equation using the equation for gravitational force. At least, I can't imagine solving it any other way.
Thanks for you answer. I did as you both suggested. The final answer is 1/10 the total distance starting from the centre of the moon.
Regards
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
