Gravitational force and distance
As one approaches the center of the Earth, the gravitational force experienced decreases due to the principles of Gauss's law, which indicates that only the mass enclosed within a radius contributes to gravitational attraction. At the center, the gravitational force effectively becomes zero because the mass of the Earth above cancels out the gravitational pull. The pressure at the Earth's core is immense, approximately 350 GPa, but this does not crush a person at the center due to the absence of gravitational force. The discussion highlights the distinction between Newtonian gravity and the behavior of gravity inside a uniform sphere, emphasizing that the gravitational field diminishes as one moves inward. Ultimately, if one could reach the Earth's center, they would not be crushed but rather experience no gravitational force.
Xile
If F=GmM / d^2 Let's assume we're using it to measure the force between me and the earth, as i go further away the force on my decreases, what would happen if i could go right to the centre of the earth? would i be crushed under the force or what?
Well for starters that equation is invalid for distances d>r; where r is the radius i.e. beneath the surface of the earth. Beneath the surface, you'll have to apply Gauss' law. Mayb that should get you thinking.
Are you familiar with Gauss's law? Use geometry to get a feel as to what the resultant force is on a particle in a hollow sphere then apply that thinking to the earth.
edit: I forgot to say that r is the radius of the earth
Im not talking about a hollow sphere, because it has to have mass to have a gravitational pull, but if i assume there was a well that went to the Earth's core, i jumped in and made it to the bottom, would i be crushed under the force when i reach the middle?
Also i don't see how Gauss's law can help me with this problem, although he states the equation i mentioned before and that gravity acts as if the mass is concentrated at the centre, I am trying to work out what would happen at the centre if i could get there.
As ranger indicated the acceleration of gravity depends on the mass enclosed in a sphere. As one goes to the center of the earth, the enclosed mass decreases.
On the other hand, the Earth's mass pulls on itself, and the pressure at the center of Earth is on the order of 350 GPa. (1 atm is ~0.1 MPa, or ~0.0001 GPa).
If one could maintain a column of air to the center of the earth, the pressure would be less since the density of the air is less than rock.
There is a Gauss's Law equivalent for gravitational field.
http://scienceworld.wolfram.com/physics/BouguerGravity.html
You have to recalculate the radial dependence for the inside solution. The 1/r^2 dependence no longer work in this region (as anyone who has done electrostatic problems can tell you).
If you assume a sphere of uniform density, you'll see that the gravitational field drops with r, not 1/r^2 for the inside solution. So the gravitational force goes to zero as r -> 0.
Zz.
Zz.
that's pretty cute. isn't there a dichotomy between Newtonian gravity and relativistic gravity at the center of the earth?
The OP was asking about gravitational force and referred to the Newtonian formula.
my question was an aside.
To calculate the force a person feels when below the surface of the Earth, you divide the Earth into two pieces:
- the solid sphere that is below him
- the hollow spherical shell that is above him
The inner sphere below him acts as a point mass.
The hollow shell above him cancels out its gravitational forces, leaving net zero because the forces felt anywhere inside any hollow sphere are net zero.
Using these, it is trivial to calculate the net forces felt at the centre of the Earth ( i.e. where the inner sphere is of radius zero - hint hint.)
