Gravitational force of the Sun and Earth
The discussion centers on finding the point between the Earth and the Sun where their gravitational forces balance each other. The gravitational force is calculated using the formula F = (G*m1*m2)/R^2, where R is the distance between the two masses. The user is attempting to set the forces equal to each other but struggles with the algebraic manipulation required to isolate the unknown distance R. They realize that R represents the distance from the center of the Earth, while the distance from the Sun would be 1.5 x 10^11 m - R. Clarification is sought on how to properly set up the equation for solving the problem.
tfugger
Earth orbits around the sun at roughly 1.5x1011 m. Mass of Earth is 6x1024 kg. Mass of sun is 1.98892x1030 kg.
There is a point between the sun and the Earth at which the gravitational force by the sun equals that of Earth and the forces cancel each other out. How far is this point from the center of the earth? You will get a quadratic equation.
I know the force between two bodies is calculated using F=(G*m1*m2)/R2
Based on the above equation, I thought that this problem would be solved by setting that equation equal to itself. Basically F=F but with the R on the right side as an unknown, then solve for that R. but obviously this results in everything else cancelling out and the R I am left with is equal to the distance between the sun and the Earth (1.5x1011 m).
So I'm confused, I'm not sure what to do...
This is an exercise in algebra more than anything else.
This magical point is at a distance R from the centre of the Earth and therefore at a distance of 1.5 x 10^11 - R from the centre of the sun.
Stick these in as your r^2 distances in the equation and you will get an equation that can be solved !
thank you very much. so does this mean my equation would be F=(G*m1*m2)/(1.5x1011 - R2) ? or is it [(G*m1*m2)/R2] = [(G*m1*m2)/(1.5x1011 - R2)
i having trouble figuring this out for some reason...
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
