Gravitational Potential Energy discussion
The discussion centers on R. Feynman's derivation of gravitational potential energy, with participants expressing confusion about the mechanics of the machines involved. Key points include the operation of two machines, A and B, which manipulate weights to demonstrate energy transfer and conservation. Participants seek clarification on the roles of the weights and the implications of their movements, particularly regarding the concept of "free power." The conversation highlights the relationship between weight, height, and energy, questioning how these principles support the idea that Y must be greater than X to prevent perpetual motion. Overall, the dialogue reflects a deep engagement with the theoretical underpinnings of gravitational potential energy and its practical implications.
physio
I have attached a discussion by R.Feynman where he derives the formula for gravitational potential energy using pure reasoning. I don't quite follow the reasoning and I have read the discussion many times yet can't get a grasp of things he says. With the discussion I have my doubts in red.
Please help if anyone can understand and follow such reasoning...
//I didn’t understand this paragraph! What weight is being lowered from
Y to X?
The three unit that was just raised to Y using machine A.
How do you run the Machine A backwards?
Forwards it lowers a one unit weight one unit distance and raises a three unit weight distance X. Backwards it raises a one unit weight one unit distance and lowers a three unit weight distance X. It is defined to be able to do this.
Which one unit weight is being lifted??
There is only one one unit weight and one three unit weight. Both machines operate on both.
What do you mean by “This will put the one-unit weight back where it was before, and leave both machines ready to be used again!”?
At the end of the sequence, both weights are back where they started, despite having extracted some energy when the three unit weight was lowered from Y to X (not using A or B).
why is it weight TIMES height?
He has shown that a one unit weight descending distance 1 can raise a 3-unit weight distance 1/3. The same reasoning shows it would lift n units distance 1/n. Clearly what's constant is weight * distance.
thanks a lot haruspex for reading my attachment and helping me out. I yet have some doubts..
1) In your first answer you say that the three unit that was just raised to Y was machine A shouldn't it be machine B??
2) How do I visualize the machines? Are they see-saws??
3) How many sets of 1 unit weights and 3 unit weights are there?
4) What do you mean by "we could lower the weight from Y to X, obtaining free power"??
Thanks a lot!
Yes, sorry, B.
I don't think Prof Feynman intended they be visualised; they're just abstract mechanisms capable of the functions stated. If it helps you to visualise them, feel free.
One of each only.
B raised the 3-unit weight to Y; A, running backwards, lowers it from X; X is below Y. So to operate B forwards followed by A backwards the 3-unit weight has to be lowered from Y to X in between. This is where Feynman points out that step could be used to obtain free energy.
You might find it clearer to think about this scenario. Suppose you had lots of sets of 3-unit weights at X and one 1-unit weight at ground level. You could run the machines like this:
A backwards raises 1-unit weight up 3 units distance, lowers one 3-unit weight distance X.
B forwards lowers the 1-unit weight back to its starting point while raising the 3-unit weight A lowered up height Y.
Repeat for the other 3-unit weights.
At the end, you've raised all the 3-unit weights from X to Y, everything else being where it started.
This is what I understood from your explanation given above...
1) We place a 1 unit weight on the rack of machine B and it lifts a 3 unit weight a distance Y.
2) We somehow lower the weight from Y to X of the 3 unit weight of machine B (How??), to obtain free energy.
3) We remove this 3 unit-weight (because we only have one 3-unit weight) and let the rack hang in air (since it is an abstract machine).
4) We place this 3 unit weight on Machine A (running backwards) and this will lift the one unit weight up a unit distance.
5) Thus, we have restored machine A to it's original condition but machine B has it's one rack hanging in mid air (at a distance X from it's starting position). The end result is that we have LIFTED a weight! (Perpetual motion).
Am I right? How does it prove Y should never be higher than X? What would it be like if we used both the machines that lifted the same distance X and lowered the 3 unit weight of machine B a little less than X (not fully) i.e n units less than X, won't we obtain the same line of reasoning as before?? How does the above case prove Y should never be higher than X?
Lastly how did he get energy=mgh from the above discussion.
Thanks again haruspex..!
Also are the machines in cascade i.e. machine B first then machine A??
This explains the fact that when the 3 unit weight is lowered from Y to X then machine A connected to machine B can use the 3 unit weight to lower it by a distance X and lift the one unit weight up a distance of 1 unit. Thus, the lifted weight of Machine B can then in turn do something useful (free power) but yet I don't understand why should Y be greater than X? How does the description explain conservation of energy??
I am very close to understanding this. Please help!
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
