Gravitational potential using spherical harmonics (WGS84)
This discussion focuses on calculating Earth's gravitational potential using spherical harmonics based on the WGS84 definition. The gravitational potential function is defined as V = (GM/r) [1 + Σ(n=2 to n_max) Σ(m=0 to n) (a/r)^n * P_nm(sin(φ)) * (C_nm cos(mλ) + S_nm sin(mλ))]. Key variables include GM (Earth's gravitational constant), r (distance from Earth's center), a (semi-major axis of the WGS84 ellipsoid), and normalized gravitational coefficients (C_nm, S_nm). The term 'd' in the context of the equations refers to the derivative.
  • Understanding of gravitational potential and its mathematical representation
  • Familiarity with spherical harmonics and their applications
  • Knowledge of the WGS84 ellipsoid parameters
  • Basic calculus, specifically derivatives
  • Study the derivation of spherical harmonics in geophysics
  • Learn about the WGS84 ellipsoid and its significance in geodesy
  • Explore the application of normalized gravitational coefficients in potential field theory
  • Investigate numerical methods for calculating gravitational potential using spherical harmonics
Geophysicists, mathematicians, and engineers involved in gravitational modeling and geodesy will benefit from this discussion.
ryan88
Hi,
I am looking to use the definition from WGS84 to calculate Earth's gravitational potential using spherical harmonics, however I am having some difficulty finding the definition of one of the variables. Gravitational potential is given as the following:
[itex]V = \frac{GM}{r}\left [ 1 + \sum_{n=2}^{n_{max}} \sum_{m=0}^{n} \left( \frac{a}{r} \right )^n \bar{P}_{nm} \left( \sin{\phi} \right ) \left( \bar{C}_{nm} \cos{m\lambda} + \bar{S}_{nm} \sin{m\lambda} \right ) \right ][/itex]
where:
[itex]V[/itex] is the gravitational potential function
[itex]GM[/itex] is the Earth's gravitational constant
[itex]r[/itex] is the distance from the Earth's centre of mass
[itex]a[/itex] is the semi-major axis of the WGS84 ellipsoid
[itex]n,m[/itex] are the degree and order respectively
[itex]\phi[/itex] is the geocentric latitude
[itex]\lambda[/itex] is the longitude
[itex]\bar{C}_{nm},\bar{S}_{nm}[/itex] are normalised gravitational coefficients
[itex]\bar{P}_{nm}\left( \sin \phi \right) = \left[ \frac{(n-m)!(2n+1)k}{(n+m)!} \right] P_{nm}(\sin\phi)[/itex]
[itex]P_{nm}(\sin\phi) = (\cos\phi)^m \frac{d^m}{d(\sin\phi)^m}[P_n(\sin\phi)][/itex]
[itex]P_n(\sin\phi) = \frac{1}{2^n n!} \frac{d^n}{d(\sin\phi)^n}\left( \sin^2\phi -1 \right )^n[/itex]
[itex]m=0,k=1[/itex]
[itex]m\ne0,k=2[/itex]
However, I can't find what the definition of [itex]d[/itex] is. Can anyone offer any help?
Thanks,
Ryan
It means derivative. As in d/dt, d^2/dt^2, etc
Ah right, now I feel stupid, lol.
Thanks for that,
Ryan
  • · Replies 17 ·
  • · Replies 30 ·
