Representing Gravity as a Vector Field
Gravity can be represented as a vector field using the formula F = -GMm/(x²+y²+z²) * u, where u is a unit vector pointing from the point to the origin. The unit vector u can be expressed as u = (x i + y j + z k) / sqrt(x²+y²+z²), allowing for the substitution into the vector field equation. This leads to the vector field representation F = -GmM/(r³) * (x i + y j + z k), where r is the distance from the origin. The divergence of this vector field can be calculated using spherical coordinates, providing insights into the field's behavior. Overall, this discussion clarifies how gravity can be modeled as a vector field and the mathematical implications of such a representation.
schaefera
In my book, it says that gravity can be thought of as a force in the form of this vector:
F= (-GMm)/(x2+y2+z2)*u
where u is a unit vector in the direction from the point to the origin. How would this be represented as a vector field (this is not a homework problem, just me wondering...)?
Is u, the unit vector, able to be split up into u= {(x)i + (y)j + (z)k}/(sqrt( x2+y2+z2), then you can sub in for that and get a vector field of the form
F=(-xGMm)/(((sqrt( x2+y2+z2)3) i + ... and so on?
Because then you can find the divergence of this vector field, but you can't find the divergence of that first equation I listed above because it's not explicitly a vector field...
You can take the divergence in the first case too. Just use the operator in spherical coordinates.
Yes,
F= -\frac{GmM}{x^2+ y^2+ z^2}\vec{u}
and
u= \frac{1}{\sqrt{x^2+ y^2+ z^2}}(x\vec{i}+ y\vec{j}+ z\vec{k})[/itex]<br /> so that <br /> F= -\frac{GmM}{r^3}(x\vec{i}+ y\vec{j}+ z\vec{k})<br /> or<br /> F= -\frac{GmM}{r^3}\vec{r}
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
Thread 'Recovering Hamilton's Equations from Poisson brackets'
The issue : Let me start by copying and pasting the relevant passage from the text, thanks to modern day methods of computing. The trouble is, in equation (4.79), it completely ignores the partial derivative of ##q_i## with respect to time, i.e. it puts ##\partial q_i/\partial t=0##. But ##q_i## is a dynamical variable of ##t##, or ##q_i(t)##. In the derivation of Hamilton's equations from the Hamiltonian, viz. ##H = p_i \dot q_i-L##, nowhere did we assume that ##\partial q_i/\partial...
