Gravity, forces, and feeling your weight
The discussion centers on the concept of weight perception in relation to gravity and forces, referencing Einstein's insights on free-fall. It emphasizes that one does not feel their weight in free-fall because there is no normal force acting against them. Weight is defined as mass times the gravitational acceleration, while apparent weight accounts for all forces acting on a body except gravity. The conversation also highlights that the difference between actual and apparent weight can be significant in scenarios like a pilot pulling out of a dive. Ultimately, feeling weight is linked to the presence of a counter force, such as a floor or chair, preventing free motion.
Tomtom
Hi there! I was wondering if you folks could give me a little enlightenment.
Two days ago, I read a quote which led Einstein to a couple of brilliant discoveries about not being able to discern a force and gravity; if you're inside a box. The quote said that Einstein was suddenly struck by the thought that a person in free-fall, does not feel his own weight.
I fully agree with that thought. But when do you feel your weight? Is it when a force acts on a object which is already being "forced" in the opposite direction? Or is it merely when you experience an acceleration?
You "feel" your weight when there is a "counter force" acting usually on your feet. In this case, we call this a normal force acting "upwards".
If you are in an elevator in a free fall, everything is falling at the same rate at any instant - you, the elevator floor, etc. So the elevator floor is not pushing back up on you. Nothing is. You no longer feel your weight. So it is this counter, normal force that gives you your feel of your weight.
Zz.
Aha ;) Thanks! (And I am familiar with Normal force, etc.)
So, could you say that you feel a force because your body is being stretched or compressed? Well, don't know if you understood my point with that one, but in any case, I feel that I understand Einstein's point. Brilliant ;)
You can never feel your own weight. You can, however, feel your apparent weight. Weight is tautologically defined as mass times the acceleration due to gravity; i.e., the gravitational force acting on a body. Apparent weight is the net sum of all forces acting on a body except for gravity. If you are standing on the surface of the Earth the two are nearly equal but opposite. (The rotation of the Earth makes your apparent weight a tiny bit smaller than your actual weight.)
To the pilot of fighter jet pulling out of a steep dive, there is a large difference between actual and apparent weight. The pilot's actual weight doesn't change, but his apparent weight can be several times your actual weight.
This is not the cause of feeling our weight, but because the strength of a gravitational field will vary somewhat over any spatially extended body, all macroscopic objects are stretched by gravitational tidal forces. This is a separate issue from feeling our own weight, though.
The reason you feel your weight is because there is a chair or floor in the way of your natural motion, to follow a geodesic in a curved spacetime.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
