Griffiths Electrodynamics gradient of charge distribution
6 replies · 5K views · last reply
Sparky_
I do not understand the following from Griffiths’ Electrodynamics – page 424 Equation 10.21.
[tex] \nabla p = \dot{p} \nabla {tr} = …[/tex]
I’m not sure how much of this applies (I think my question is on the math) but p is the charge distribution, tr is the retarded time.
Is this an application of the chain rule?
With the gradient being a derivative with respect to spatial location (x,y,z), why is the time derivative showing up in the gradient? I initially want to say if something is dependent upon t but not on x, then its derivative with respect to x is zero.
The result looks like the chain rule applied – I don’t see why the time dependent portion shows up.
Can you help clear this up for me?
Thanks
Sparky_
I do not see it yet.
I see later on the same page
[tex] \nabla \dot{p} = \ddot{p} \nabla {tr} = …[/tex]
Can you explain further?
Somehow the gradient is giving an additional time derivative.
Thanks
Sparky_
[itex]\rho[/itex] has arguments like this:
[itex]\rho (\vec{r}', t_r(\vec{r}, \vec{r}', t))[/itex]
The gradient is being applied w.r.t to the coordinates of [itex]\vec{r}[/itex] ( not [itex]\vec{r}'[/itex] which gets integrated away). The coordinates that we would be taking the derivative with respect to in order to obtain the gradient are only found in the parameters of [itex]t_r[/itex]. So this result is from the chain rule. Here is one component of the gradient, for example.
[itex](\nabla \rho)_x = \frac{\partial \rho (\vec{r}', t_r(x, y, z, \vec{r}', t))}{\partial x} = \dot{\rho}\frac{\partial t_r}{\partial x}[/itex]
Oh I see, did he specify that the dot derivative is with respective to retarded time?
It won't matter. ##\partial _{t_{r}} = \frac{\partial t_{r}}{\partial t}\partial _{t} = \frac{\partial }{\partial t}(t - \frac{\mathfrak{r}}{c})\partial_{t} = \partial_{t}##.
Anyways, as noted above ##\rho = \rho(r',t_{r}) ## and ##r'## is no longer a variable after integration but ##t_{r} = t_{r}(t,x,y,z,r')## so ##\nabla \rho = \partial _{t_{r}}\rho \nabla t_{r} = \partial_{t}\rho \nabla t_{r}##. Not sure what that has to do with the conservation of 4-current (continuity equation) ##\partial_{a}j^{a} = 0##.
Thank you!
I went back in this section of the text and reread. I see that p (charge density) is specified p(r’, tr). That is actually the point of this topic (the nonstatic case).
You confirmed that this is an application of the chain rule and p is a function of position and tr.
Thank you for the help!
Sparky_
