Grounding Op-Amp circuit exercise
15 replies · 2K views
Weaver
2. Homework Equations
3. The Attempt at a Solution
For the first set of questions:
I've worked through to part 6), at which is I encountered my first problem. I'm not entirely sure what the question is asking. Is it as if there would be a capacitor between Q1 and X1? Is the voltage to be reduced the one calculated in part 5)?
Moving on from that
I am also unsure about part 9) and 10). We haven't really covered MOSFETs in lectures so these two questions are a bit lost on me. Do I use the frequency, current and resistance to get the average value?
For the second answer sheet for I haven't worked out 5), 7), 9), 12) However I am working on this right now. I will probably have questions later on this
I don't want the answers, but rather help on what methods I should be doing or perhaps pointers to resources that would help
Also, I'm not even certain what I have done is correct
I appreciate any help
Thanks in advance,
anorlunda said:
Those images under attempt at a solution are too poor quality to read. You probably won't get any answers until you post something more legible.
Thanks for that. I'm at uni, so I don't have access to a scanner. I will update them later tonight
I've decided to make smaller threads asking about the problems i have been having more specifically with typed solutions (my scanner broke) so that it is easier to follow. I would delete this thread, but I don't know how
https://www.physicsforums.com/threads/calculate-current-following-in-op-amp-to-ground.959831/
https://www.physicsforums.com/threads/decoupling-capacitor-for-pcb-track.959829/
https://www.physicsforums.com/threads/ground-current-for-voltage-regulator.959832/
It was a mistake to have several threads running on the same problem.
Regarding the capacitor on X1 Q1... they are talking about a decoupling capacitor you need to add. It would be on the 24V rail. See my reply in your other thread where I mention ripple currents.
Apologies for that. I thought it might help break up the question. I won't do it again. Thanks for replying in the other forum
I haven't looked at your working for 1-6 properly but..
For 9. It asks you to calculate the voltage drop down a typical PCB trace due to the 10mA FET gate current. Use the frequency you calculated in 8.
EDIT: In case it's not obvious this current flows in and out of the MBED power/ground pins on it's way to/from the FET gate.
For 10: Similar to Q6
Thank you very much! I get and I think I have those out figured. When it asks average AC, does that mean RMS?
I’ve followed through with the rest of the questions. The last one I have a problem with the op amp ground current
Should there be a value in a data sheet for this? Or is it calculated?
If it’s calculated, at worse case, the op amp will have 0V at it’s In(+) so no voltage appears at the output. So at this point it is just the supply current into the op amp?
That's what I would answer. Not sure why they ask for that as it's the peak to peak that more important.
Edit: Earlier they suggest you model the output as a 10mA current source feeding the gate capacitance of the FET. So perhaps think carefully about the waveform and how you do the rms calculation.
I agree.
Right, so the waveform is generated from the resistance and inductance of the the PCB with the ripple current produced from the MOSEFT. In this case is the Vripple close to a square
waveform as it is the MOSFET switching?
(By the way, I really appreciate all the help you've given)
No isn't this Q9 where they ask about the MPEG average AC current? Eg due to the FET gate current not the source/drain current.
What I was hinting at is that a constant current (10mA) driving a capacitor (FET gate) produces a triangle wave
Actually forget that. The gate voltage will be a triangle wave but the ripple on the supply voltage will be a square wave as it's the constant 10mA * PCB trace impedance.
Okay, so as it's a square wave, the Vrms is just the peak voltage in this case?
CWatters said:
Yes that would be my answer for that question.
Great! Thank you for all the help you've given. Definitely helped improve my understanding! Really appreciate it
