Group like terms factoring problem
The discussion focuses on factoring the expression (x-y+2√x-2√y)/(√x-√y). Initially, like terms are grouped, leading to the expression (x+2√x-y-2√y)/(√x-√y). The next step involves factoring out √x and -√y, resulting in ((√x)(√x+2)- (√y)(√y+2))/(√x-√y). The user expresses uncertainty about progressing to the next step, which involves recognizing that x-y can be factored as (√x+√y)(√x-√y). The conversation concludes with the realization that this approach simplifies the problem effectively.
kuahji
(x-y+2\sqrt{x}-2\sqrt{y})/(\sqrt{x}-\sqrt{y})
The first thing I did was group like terms
(x+2\sqrt{x}-y-2\sqrt{y})/(\sqrt{x}-\sqrt{y})
Then from the liked terms I factored out a \sqrt{x} & -\sqrt{y}
((\sqrt{x})(\sqrt{x}+2)-(\sqrt{y})(\sqrt{y}+2))/(\sqrt{x}-\sqrt{y})
Here is where I get stuck. The next step should be, ((\sqrt{x}-\sqrt{y})(\sqrt{x}+\sqrt{y}+2)/(\sqrt{x}-\sqrt{y})
However I'm just unsure how to jump to that next step.
I think you want to use x-y=(sqrt(x)+sqrt(y))*(sqrt(x)-sqrt(y)).
Thanks, that works out much nicer.
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
