Guitar Pickups - Shapes of magnets used and their importance
The discussion revolves around the shapes of magnets used in guitar pickups, specifically the implications of using different shapes, such as triangular prism magnets instead of the standard cylindrical type. Participants explore the importance of magnet shape in relation to sound production and the feasibility of creating custom pickups.
  • One participant questions the common rod shape of magnets in guitar pickups and wonders about the feasibility and effects of using triangular prism magnets instead.
  • Another participant clarifies that the term "pole-pieces" is more accurate than "magnets" when discussing the shapes used in pickups, suggesting that various shapes can work but manufacturing costs may be a concern.
  • A different viewpoint suggests that using different grades of Alnico magnets could affect the sound, and warns against using magnets with sharp angles due to their lower coercivity.
  • One participant provides a detailed explanation of how the shape of the magnet affects the magnetic field strength and direction, emphasizing the importance of the rod shape for sound clarity.
  • It is noted that while different shaped magnets can be used, they may alter the pickup's performance and sound characteristics.
Participants express a range of views on the implications of using different magnet shapes, with no consensus on the best approach or the extent of the impact on sound quality. Some agree on the feasibility of various shapes, while others raise concerns about practical considerations.
Participants mention the importance of considering the properties of magnets and their interaction with guitar strings, but do not resolve the specifics of how different shapes might affect performance.
MathsRetard09
I'm not electrical minded but I am wondering why my guitar pickup like most have the these rod shaped magnets.
Why are they that shape and why is it important?
I would like to make my own pickup to understand better how it functions and to see if I can achieve the attempt in making one.
But I'm wondering what other shaped magnets I could use instead.
I know the magnet(s) would have to lay beneath all the strings of the guitar.
I would like someone to enlighten me some knowledge on this and also answer this question too:
If they exist as I am not sure if they do, but if I used triangular prism rod shaped magnets instead of the standard cylindrical type, would it change anything drastic? would the pickup work?
I'm asking because I want my pickup to look different, instead of these round things behind my strings I want to have triangles instead. I just don't know if it's even possible to do this and whether there's some physical law that states magnets have to be a particular shape to work properlly etc..
I am a mechanical engineer which possibly explains my lack of intellect due to the overuse of using hammers however please, if you understand what I'm on about and would like to help me out then please do not hesitate to reply.
Thanks.
What you are asking about is pole-pieces, not magnets. If you look at pickup designs over the years, you will find that almost any shape will work for pole-pieces. Bars, rectangles, cylinders, pairs of cylinders... I'm sure that pole-pieces with a triangular cross-section would work just fine, but think of the manufacturing costs. What is easier to make, economically? Machining cylindrical or rectangular pole-pieces is pretty straightforward. Machining triangular pole-pieces or even odd cross-sections like stars, etc costs money with no obvious advantage.
If you want to make your magnet unique sounding, you could try a different grade of Alnico. Most pickups use Alnico 3 or Alnico 5. You could even magnetize them yourself if you wanted. I am no expert in the matter but I am trying to magnetize some big alnico blocks right now (you can see it in my 30V 200A pulse thread a few topics below yours). From what I know though, I would suggest against using an Alnico magnet with such sharp angles, because it has very low coercivity vs. remnance compared to other magnets, meaning that it is easily demagnetized unless it is long. I don't own any pickups, but I don't think I remember seeing pole pieces (pieces of iron stuck to the ends of a magnet to guide flux) on the outside of the guitar. Correct me if I'm wrong, but right under each string you have a magnet, I don't think there's a pole piece in between, but i could be wrong. If there is then it really shouldn't make a difference what shape it is so u can make them into stars or skulls or whatever
thanks guys makes sense :)
I can provide some insight into the shapes of magnets used in guitar pickups and their importance. The most common shape for guitar pickup magnets is the rod shape, which is typically made of Alnico or ceramic material. This shape allows for a strong magnetic field to be created and focused directly under the strings of the guitar, which is essential for producing a clear and powerful sound.
The specific shape of the magnet is important because it affects the strength and direction of the magnetic field. In a guitar pickup, the magnetic field needs to be strong enough to vibrate the strings and create a signal, but not so strong that it interferes with the vibration of the strings. The rod shape is ideal for this because it allows for a strong field to be focused directly under the strings, while minimizing interference with the string vibrations.
In terms of making your own pickup, it is possible to use different shaped magnets, but it may affect the overall performance of the pickup. For example, using triangular prism rod shaped magnets instead of cylindrical ones may alter the strength and direction of the magnetic field, potentially resulting in a different sound. It is important to consider the properties of the magnets and how they will interact with the strings before making any changes.
In terms of physical laws, there are no strict rules for the shape of magnets used in guitar pickups. However, the shape and material of the magnet will affect its magnetic properties, so it is important to choose a magnet that is suitable for the specific application.
In summary, the rod shape of guitar pickup magnets is important for creating a strong and focused magnetic field under the strings, essential for producing a clear and powerful sound. While it is possible to use different shaped magnets, it is important to consider their properties and how they will affect the overall performance of the pickup. I hope this helps to answer your questions and guide you in your pursuit of making your own pickup.
  • · Replies 25 ·
  • · Replies 21 ·
  • · Replies 165 ·
12K
