Gyroscope Precession: Understanding Angular Momentum & Energy
Gyroscope precession occurs due to the torque from gravity acting on the pivot, which rotates the existing angular momentum vector. The discussion raises a question about the origin of vertical angular momentum, noting that there is no initial torque in that direction. It is suggested that precession can occur without torque if the system rotates about its principal axes, as seen in the Earth's free-fall orbit. The relationship between gravitational potential energy and precession is questioned, particularly since the motion is primarily horizontal. Understanding these concepts may require revisiting Euler's equations and related dynamics.
transparent
Hello. I know there are quite a few threads about this, but I couldn't find what I was looking for. This topic has been driving me crazy over the last couple of days. I know the cause behind the precession. It's because the torque due to gravity about the pivot tends to rotate the already present angular momentum vector since it is always perpendicular. This is only possible by rotating the wheel itself, thus causing the precession. What I don't understand is where the angular momentum in the vertical direction comes from, since it was not present initially. There is no torque in the vertical direction. And what about the energy due to precession? Is it because of some change in gravitational potential energy? This seems unlikely since the entire motion of the centre of mass of the disc is in the horizontal plane. Any help will save me from insanity.
Find an old Sperry Gyroscope technical manual.
This can be analyzed using the Euler's equations...which I haven't worked with in several years. However, I'd like to point out that there does not necessarily need to be a torque in order for precession to be present. In fact, since the force of gravity acts on the center of mass of the system, it does not, if I recall correctly, present a torque to the system if the system is rotating about its principle axes. The Earth, for example, is in free fall orbit and there are no torques really acting on it, and yet its rotation precesses once every ~10,000 years. There is also a nutation present.
Maybe look here for some more details:
http://en.wikipedia.org/wiki/Euler's_equations_(rigid_body_dynamics)
I'd suggest watching this video.
http://ocw.mit.edu/courses/physics/8-01-physics-i-classical-mechanics-fall-1999/video-lectures/lecture-24
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
Thread 'Recovering Hamilton's Equations from Poisson brackets'
The issue : Let me start by copying and pasting the relevant passage from the text, thanks to modern day methods of computing. The trouble is, in equation (4.79), it completely ignores the partial derivative of ##q_i## with respect to time, i.e. it puts ##\partial q_i/\partial t=0##. But ##q_i## is a dynamical variable of ##t##, or ##q_i(t)##. In the derivation of Hamilton's equations from the Hamiltonian, viz. ##H = p_i \dot q_i-L##, nowhere did we assume that ##\partial q_i/\partial...
