JTC
- 100
- 6
Say I have a disk spinning in a buoy. Let me say the spin axis is vertical to the flat surface of the buoy (or sea if there were no waves).
Now along comes a wave (that will induce a "precession" of the disk/buoy. The axis of this precession is from "starboard to port."
This would induce (due to the gyroscopic effect) an angular velocity of that rotor disk, about an axis that goes from bow to stern.
So let me assume I can do a very simple, back of envelope (assuming all is at the center of mass), calculation to calculate the induced angular velocity from the mass, geometry, etc.
How do I get as similar "quick and dirty" estimation of the power generated?
You see, the issue is that I do not know how generators work.
I do know that Power = Torque * angular velocity.
I just found the angular velocity
Do I simply add to my formula a "hypothetical" torque that would STOP the rotation? And assume that this torque times the rotation rate without the torque is an estimation of the generated power?
But this makes no sense because Power = Torque times the angular velocity it rotates. Here, I would be applying a torque to COUNTER the angular velocity.
I am not looking for anything complicated. I have tried to read the on-line sources. But I cannot frame this problem in my head (or even try to read the sources), until I figure out how to estimate the power.
(And yes, i am aware there is induced yaw, pitch, roll due to ONE gyro, but let's keep this simple... In THIS context, HOW do I estimate the generated power? How does a generator work?)
