What Are the Fourier Coefficients for the Half-Range Cosine Series of f(x)=x?
The discussion focuses on finding the Fourier coefficients for the function f(x) = x defined on the interval 0 < x < L. The initial calculations yielded a_0 = L and a_n = 4L/n^2 pi^2, but the correct values are a_0 = L/2 and a_n (for odd n) = -4L/n^2 pi^2, with a_n being zero for even n. The correction is supported by the observation that shifting the function creates an odd function, which only requires sine terms in its Fourier series representation. Participants emphasize the need for detailed calculations to identify mistakes in the original attempt.
v_pino
The function f(x) is defined on the interval 0<x<L by f(x)=x. It can be represented by the Fourier cosine series
f(x) = a_0 + sum a_n cos(n*pi*x / L)
Find its Fourier coefficients a_0 and a_n.
Multiply both sides by cos(n*pi*x / L) and integrate from L to 0. Then integration by parts.
I got a_0 = L and a_n = 4L/ n^2 pi^2
The answers should be : a_0 = L/4 and a_n = -2L/n^2 pi^2 for n = odd and a_n=0 for n = even.
thanks!
The give answer is not quite correct, but neither is yours.
a_0 should be L/2 and a_n(odd) = -4L/(n^2 pi^2).
The value for a_0 can be seen to be correct by shifting the function by L/2 to the left. Then it is an odd function up to the shift upwards by L/2. So it can be represented by only sines, which explains that even values of the cosine are 0.
If you want us to find your mistake you have to post your calculation.
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
