Half wave vs peak detector circuit
The half-wave rectifier circuit only allows the positive half-cycles of an AC signal to pass, delivering zero volts between these cycles. In contrast, a peak detector holds the peak voltage of the AC signal, providing a steady output that reflects the most recent peak rather than half-cycles. While both circuits share similar components, the peak detector typically requires an operational amplifier to accurately capture the peak voltage without losing it across the diode. The choice between a half-wave rectifier and a peak detector depends on the specific application, particularly in projects requiring DC signals from AC sources. For sensor circuits in applications like autoguided vehicles, the peak detector may offer advantages in smoothing the output.
onceinalifetim
hello
I would like to know what is the different between half wave rectifier circuit and peak detector circuit..
as what i know from half wave.. it only take the positive wave only..
then what about peak detector ??
The half wave delivers, say, the positive half cycles. Between those half-cycles it delivers nothing, i.e., it delivers zero volts.
The peak detector holds its value, so it doesn't deliver anything recognizable as half-cycles. Between the peaks of the AC it delivers the same voltage as the last peak. Instead of half-sinusoids, it delivers a roughly steady level, equal to the peak value of the most recent positive half-sinusoid.
For further detail, google.
do they work the same way? thanks for the reply
A peak detector should do something more along the lines of this (this one is self resetting, it doesn't need to be! it might just hold the peak, that's what 'traditional' ones do)
They don't work in exactly the same way although they have similar components. The peak detector for any practical purposes usually requires an op amp. You can build one without an op amp, but you will not detect the peak as you will lose some voltage across the diode which prevents the 'peak' from discharging. The op amp can be used to compensate the diode drop. http://en.wikipedia.org/wiki/Precision_rectifier
Please check out this thread about a peak detector build here:
https://www.physicsforums.com/showthread.php?t=713307
That depends on the application. There are places where you could replace one by the other, but mostly not.
The peak detector has already begun the process of "smoothing", whereas the half-wave rectifier shows no smoothing.
the reason why i ask because I am currently working on a autoguilded vechile project and am doing the sensor circuit... my PIC need DC signals.. so i need to change AC to DC.. that why am thinking to choose half wave or peak detector..
I am trying to understand how transferring electric from the powerplant to my house is more effective using high voltage. The suggested explanation that the current is equal to the power supply divided by the voltage, and hence higher voltage leads to lower current and as a result to a lower power loss on the conductives is very confusing me. I know that the current is determined by the voltage and the resistance, and not by a power capability - which defines a limit to the allowable...
  • · Replies 27 ·
  • · Replies 23 ·
  • · Replies 33 ·
13K
  • · Replies 39 ·
