Understanding the Hall Effect: Explanation of Electrons and Resultant Voltage"
  • Thread starter Thread starter 6021023
    Hall effect
The Hall Effect occurs when electrons move through a conductor placed in a magnetic field, resulting in a voltage perpendicular to both the current and the magnetic field. This phenomenon is explained by the Lorentz force, which acts on the electrons, pushing them to one side of the material and creating a charge imbalance. As a result, one side of the slab accumulates more electrons, leading to a measurable voltage across the material. The voltage arises from this separation of charge, which is a fundamental characteristic of the Hall Effect. Understanding this effect is crucial in various applications, including sensors and measurement devices.
6021023
Can someone explain the Hall Effect? If electrons are moving inside a magnetic field that is perpendicular to the wire, then perpendicular to both the wire and the magnetic field will be a resultant voltage? Why does this voltage arise?
Do you know about Lorentz force?
Because that basically explains it.
You are driving a current to a slab of material. To be rigorous, let's put the material in the (x,y) plane and let the current flow in the x-direction*. If you also apply a magnetic field in the z-direction, then the electrons that make up the current will experience a Lorentz force. By the basic physical laws, this force acts in the y-direction. So inside the slab, in the direction perpendicular to the currrent, a voltage is building up. After all, this means precisely that on one side electrons "clutter" together and on the other side they become scarcer. This can indeed simply be measured by applying a volt meter across the material in the y-direction.
[small]*) I'm not thinking about directions here: that's a little tricky with the conventions for current flowing in the opposite direction as the actual current carriers, the electrons. I suggest you sit down and work it out for yourself.[/small]
The Lorentz force causes the electrons to clutter, which creates a voltage?
Well, not really.
It just draws electrons more to one side of the material than to the other side.
So there is more charge on one side than on the other side.
Of course, this is precisely what we mean by a "voltage".
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'A scenario of non-uniform circular motion'
(All the needed diagrams are posted below) My friend came up with the following scenario. Imagine a fixed point and a perfectly rigid rod of a certain length extending radially outwards from this fixed point(it is attached to the fixed point). To the free end of the fixed rod, an object is present and it is capable of changing it's speed(by thruster say or any convenient method. And ignore any resistance). It starts with a certain speed but say it's speed continuously increases as it goes...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
