Hard potential energy function question
The discussion revolves around deriving the force on a particle from a given potential energy function, V(x) = (ka^2)/((x^2)+(a^2)). Participants clarify that potential energy is not simply the product of potential and mass, and that charge is not necessary for expressing force in this context. The correct approach involves using calculus, specifically taking the gradient or derivative of the potential function. The formula for force is established as F = -dV(x)/dx. The conversation concludes with a confirmation that understanding the gradient is key to solving the problem effectively.
Lucy Yeats
Potential energy function A particle of mass m, starting from x = −∞, approaches
a force region whose potential is given by
V (x) =(ka^2)/((x^2)+(a^2))
where V0 > 0 and a are constants.
(a) Derive an expression for the force on the particle as a function of
E=F/Q, V=W/Q, E=V/d
I tried to substitute it into the equations above, but it didn't work. A friend thought the answer involved calculus, but I'm not sure where to start. Any hints would be much appreciated...
Is it correct that potential x mass = potential energy?
Do I need to introduce a constant for the charge, of can I express F without this? Help, please! Thanks! :-)
No.
Check your thread which directly asks this question.
Lucy Yeats said:
Do I need to introduce a constant for the charge, [STRIKE]of[/STRIKE] or can I express F without this? Help, please! Thanks! :-)
You don't need the charge.
You can express F without introducing a charge.
Do you know how to take the gradient?
F = - V .
Otherwise, F = - dV(x)/dx .
Thanks SammyS, you post about the gradient answers the question perfectly!
