Hello
Sorry for the delay, I broke my little toe yesterday and I spent the day in the hospital.
*-Thank you for answering; I didn't expect so many people here :)
*-Yes, I assume the GR is tested enough.
*-I used the word [relativistic] "corrections", but maybe it's an error of translation; other expressions, as "mass factors" or "mass contributions" (with respect to SR, or even to classical mechanics), might sound better.
PeterDonis said:
if we were deep inside the pulsars's gravity well
You're right, my fault.
PeterDonis said:
Relativistic corrections to "rate of time flow" without any consideration of the particular dynamics of a system. Not relativistic corrections to a classical model of the internal dynamics of pulsars.
Yes; I thought the question should be about the simplest case.
@ghwellsjr,
@PeterDonis: maybe the first question wasn't enough clear (sorry for that). I will try to remake it:
-has a real clock a "rate of time flow" different from a mathematical/ideal clock?*
-If the answer is yes, what is the order of magnitude of this difference? (and, what can be the origin of the difference? I supposed the GR)
PeterDonis said:
we can't observe directly the parameters that would determine the rotation rate [...] we have no way of checking the parameter values to see which model fits the data.
I read that some pulsars are more precise than atomic clocks, and because of that, I used the idea in the example. I'm not an astronomer (and I've never met any), so if the next sentence sounds stupid, please just overlook it: I've heard the pulsars lose their kinetic energy by radiation, so, is it possible to compare the rate of radiation and the rate of frequency, and use them as a way to check the theories? (classical mechanics, SR and GR)
@harrylin: mmm... I had not thought about the trueness (accuracy) of the astronomers' measurements, good remark :)
On the other hand, I think GR affects atomic clocks too, although they works at quantum levels (Wu et al made an experiment with quantum interference, testing successfully the GR). My doubt is the order of magnitude of the difference between an ideal clock (the clock which measure the "time" in the mathematical expressions of SR and GR), and the atomic clock of 2 lb which is in a lab :)
harrylin said:
let's see if I understood him correctly.
Yes, yes, thank you very much :) :)
Sorry for such a long statement; I tried to sum it up. And again, please, forgive my grammar errors, and I'll be glad if you correct any mistake.
Greetings.
*Maybe I should make a clarification: I refer to an ideal clock as a clock which measure the parameter "time" that appears in the equations; and to a real clock as a clock which is used in the real life.
PS: I thought the words accuracy, trueness and precision have the meaning which is explained here:
http://en.wikipedia.org/wiki/Accuracy_and_precision#Terminology_of_ISO_5725
