Struggling with AP Physics Problems: How to Correct My Calculations?
  • Thread starter Thread starter wtf_albino
    Physics
wtf_albino
Hey everyone! I'm new to the forums:biggrin: I just started AP Physics a few days ago and I'm having some trouble on the following problems:
1) A truck on a straight road starts from rest accelerating at 2.0 m/s^2 until it reaches a speed of 20 m/s. Then the truck travels for 20 s at a constant speed until the brakes are applied, stopping the truck in a uniform manner in an additional 5.0 s. (A)How long is the truck in motion? (B)What is the average velocity of the truck for the motion described?
______________________________________________________________
For (A) I found the correct time to be 35 s.
For (B), I used the equation:
Average velocity = (Vo + V)/2
I set it up like:
V = [(0 m/s) + (20 m/s)] / 2
i came up with 10 m/s as my velocity which was wrong. I know this is kind of a multifaceted problem and I'm having trouble adjusting the equation accordingly. Can someone please point out my error and how i can solve this?
2) A cesna aircraft has a lift-off speed of 120 km/h. (A) What minimum constant acceleration does this require if the aircraft is to be airborne after a takeoff run of 240 m? (B) How long does it take the aircraft to become airborne?
_____________For this problem i used the equation:
V^2 = Vo^2 + 2ax
I set it up like:
(120 km/h)^2 = (0 km/h)^2 + 2(a)(.240 km)i came up with 30,000 km/h^2 which doesn't sound right at all:confused: Can someone please point out my error and how i am able to better approach this problem?Help would be very much appreciated thanks!:biggrin:edit: sorry for the vague title, i'll be sure to make it more specific next time.
No. Average velocity is total distance/total time.
V^2 = Vo^2 + 2ax
I set it up like:
Convert km/hr to m/sec.
It is easier to determine the time first. If it has constant acceleration and ends up traveling at 120 km/hr (33.3 m/sec), what is the average speed? What is the distance in terms of average speed and time?
Once you have the time, you can easily find the acceleration.
AM
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
