Heat Capacity & Density: Math Relation Explored
  • Thread starter Thread starter LeoYard
    Density Heat
Heat capacity is mathematically related to density, with the relationship influenced by molecular structure and phase (solid, liquid, or gas). A decrease in density may lead to an increase in degrees of freedom and entropy, although this effect varies across different materials. Interatomic and intermolecular forces change with density, affecting atomic vibrations and introducing new vibrational modes. The behavior of substances, particularly gases and liquids, is significantly temperature-dependent, complicating the relationship further. Overall, while some connections exist, a general formula remains elusive due to these complexities.
LeoYard
How does heat capacity relate (mathematically) to density?
I imagine first relating entropy to density, it will depend on the molecular structure and everything, but is there a general formula ?
http://en.wikipedia.org/wiki/Volumetric_heat_capacity
I found this link, and it deals with Volumetric Heat Capacity. It is not exactly what I'm looking for.
Can one make the assumption that decrease in density leads to increase in degrees of freedom, entropy?
Science news on Phys.org
The effect may depend on the phase: solid, liquid or gas. Even in solids, metals, ceramics, organic molecules are all different.
Some relevant discussion, but not enough detail.
http://hyperphysics.phy-astr.gsu.edu/hbase/thermo/dulong.html
http://hyperphysics.phy-astr.gsu.edu/hbase/thermo/inteng.html
Certainly the interatomic or intermolecular forces change with decreasing density, which would seem to introduce changes in atomic vibration and perhaps introduce modes which would otherwise not be present because of constraint. The amplitude of vibration would also change.
Thank you for the links. So, we can't be more specific than that. I thought of excluding solids. But, still the way substance (gas or liquid) behaves depends very much on its temperature in non-trivial ways.
Thread 'Thermo Hydrodynamic Effect'
Vídeo: The footage was filmed in real time. The rotor takes advantage of the thermal agitation of the water. The agitation is uniform, so the resultant is zero. When the aluminum cylinders containing frozen water are immersed in the water, about 30% of their surface is in contact with the water, and the rest is thermally insulated by styrofoam. This creates an imbalance in the agitation: the cold side of the water "shrinks," so that the hot side pushes the cylinders toward the cold...
