Heat and temperature question with calorimetry
The discussion centers on a calorimetry problem involving a 2.0 kg metal with a specific heat capacity of 620 J/kg·K and 1.5 kg of water initially at 20°C. The final temperature, after adding 80,000 J of heat, is calculated to be 303.6 K. The equation used is Q = mcΔT, where the heat added is treated as negative in the context of the energy balance equation. The correct interpretation of heat transfer is clarified, emphasizing that the heat gained by the water and metal equals the external heat added.
  • Understanding of calorimetry principles
  • Familiarity with the equation Q = mcΔT
  • Knowledge of specific heat capacities of water and metals
  • Basic algebra for solving equations
  • Study the concept of heat transfer in calorimetry
  • Learn about specific heat capacities of various materials
  • Explore advanced calorimetry techniques and applications
  • Investigate the implications of energy conservation in thermal systems
Students studying thermodynamics, physics educators, and anyone interested in understanding heat transfer and calorimetry calculations.
Lisa Marie
2.0kg of a metal (for which c = 620 J kg K ) is immersed in 1.5kg of water, initially at 20◦ . What is the final temperature if 8.0 × 104J are added as heat?
Q=mcΔT
So I was able to get the correct answer what I did was:
Qadded heat+mcΔTiron+mcΔTwater=0
-8×104 +2(620)(Tf-293)+1.5(4200)(Tf-293)=0
doing the algebra will give you 303.6 K which is correct...but I was just wondering why is the heat added negative?
Q=mcΔT
I assume the metal initial temp. was 20C also.
Your equation is conceptually somewhat unwieldy. More obviously,
heat gained by water + heat gained by metal = external heat added
which is your equation also if you move the external heat to the rhs of your equation.
10K
