Heat engine and Heat pump in combination
3 replies · 5K views
canadiansmith
Question is attached
I have spent a great deal of time on this problem and I am hoping someone can help me out.
My attempt at problem.
first for the heat engine
QL/Qw1 = TL/Twaste
so efficiency = 1- Tl/Twaste
efficiency = 0.93808
and I know that efficiency = Wout/ Qw1
This is as far as i got for the heat engine...
For Heat pump
i found cop = TH/(TH-TL) = 4.23
Never mind efficiency. The problem doesn't ask for efficiency. It only wants you to compute dQh/dt.
ANYWAY ...
write the equations for the 1st and 2nd laws. That's 4 equations.
Then write the relationship between Qw1, Qw2 and 5 MW.
5 equations, 5 unknowns. Away you go. Solve for Qh.
(Note - the 1st and 2nd laws are usually written in terms of energy rather than power. Don't let that slow you down. Just pretend it's energy for 1 second, which of course is 1 J/s = 1 W.
ANYWAY ...
I am still a little confused. There are 2 equations for both first and second law?
i only have delta U = Q-W
and Q = integral of TodeltaS
Yes, but you have two mechanisms, the heat engine and the heat pump. Each has its own
1st & 2nd law equations.
BTW dQ = TdS is not an expression of the second law. It's just a formula to calculate entropy. What you need is an expression reflective of the fact that entropy is unchanged in a reversible cycle.
As for the 1st law, you are right, but what can you say about Qw1, QL, Qw2, QH and W? Remember that U is a state function so over a cycle it doesn't change either, reversible or not.
