Heat & Movement: Frame of Reference & Kinetic Energy
  • Thread starter Thread starter rich tea
    Heat Movement
The discussion centers on the relationship between temperature, kinetic energy, and the movement of air particles. A physics teacher in training questions whether moving air, such as from a fan, increases the temperature of that air due to an increase in total kinetic energy. The response clarifies that temperature is a measure of the average kinetic energy of air molecules in a frame where the momentum is zero, indicating that temperature is not frame-dependent. While moving air does have kinetic energy, this energy becomes random as the air interacts with other molecules and surfaces, ultimately leading to a rise in temperature only after these interactions. The cooling effect felt from a fan is attributed to the evaporation of moisture from the skin, rather than a decrease in air temperature.
rich tea
hello, my first post here, I'm training as a physics teacher and my physics is quite rusty, it's been a good few years since university, i was thinking about heat (of air for example) being the kinetic energy of the particles and then i thought if that was the case wouldn't a mass of air with a certain temperature increase in temperature if it started to 'move' for whatever reason (wind, a fan...) as the total kinetic energy of that air would increase.
Does this have anything to do with the frame of reference you use to calculate the air particles' total Kinetic energy, do you use some kind of internal frame of reference?
Or have i completely confused myself?
this is bugging me, hope someone can help
Science news on Phys.org
Exactly. You'd use a frame in which the momentum is zero.
Actually it is not all that straight.Yes, the heat energy is due to increase in the K.E of the molecules present in the air. Actually when the wind speed is normal , the molecules are randomly striking the walla of the room , remember the kinetic energy is still present , and when wind/speed increases, the motion becoms more random , the more random and tedious motion , more the probability that the momentum's carried by th emolecules keeo on cancelling on striking the walls and against other equally sized molecules.Therefore we feel comfortable under fan.
rich tea said:
... wouldn't a mass of air with a certain temperature increase in temperature if it started to 'move' for whatever reason (wind, a fan...) as the total kinetic energy of that air would increase.
Just to be clear, the answer to that is no. Temperature is a measure of the average KE of the molecules in a frame in which the momentum is zero. Otherwise, temperature would be frame dependent.
Of course, the macroscopic KE of the air imparted by the fan soon becomes random KE and an increase in temperature, but that's only after the moving air is slowed down by collision with other air molecules in the room and with walls, etc. (We feel comfortable under a fan because the moving air helps evaporate moisture on the skin, thus cooling us off. But having a fan on will increase the temperature of the room.)
thanks doc al, i suspected it could be this something like this, so you could kind of say temperature is measure of the mayhem going on around you when you're sat in the middle of things
Thread 'Thermo Hydrodynamic Effect'
Vídeo: The footage was filmed in real time. The rotor takes advantage of the thermal agitation of the water. The agitation is uniform, so the resultant is zero. When the aluminum cylinders containing frozen water are immersed in the water, about 30% of their surface is in contact with the water, and the rest is thermally insulated by styrofoam. This creates an imbalance in the agitation: the cold side of the water "shrinks," so that the hot side pushes the cylinders toward the cold...
