Absentee
- 23
I believe I'm missing something, probably a very stupid question incoming:
I am considering process with ideal gas expanding without piston-friction in constant temperature environment. Amount of heat taken from the reservoir is of the same amount as the work done by the expansion of the gas.
ΔU = Q - W
Since there is no change in temperature:
Q - W = 0
Let's consider process where the same ideal gas expands for the same amount of ΔV but this time with piston-friction.
ΔU = Q + Q(Friction) - W
Q + Q(Friction) - W = 0
So the "sum of heats" is of same amount as the work done, so less heat had to be taken from the reservoir, as the friction added some heat itself.
But how do I explain this practically? What it means for me is that I need less heat taken from the source for the same amount of work. How is that bad? What am I missing?
ΔU = Q - W
Q - W = 0
