Heat of Why Does Reaction Proceed Anyway?
  • Thread starter Thread starter brake4country
    Heat
The discussion centers on the dissolution of solid potassium chloride in water, questioning why the reaction occurs despite the bonds formed being lower in energy than those broken. The key point is that the increased disorder from mixing the solute and solvent leads to greater entropy, driving the reaction forward. The participant expresses confusion over the relationship between bond energy and reaction type, mistakenly associating lower energy with exothermic processes. The solution clarifies that lower energy in this context indicates an endothermic reaction, challenging the participant's understanding of stability and energy dynamics. Ultimately, the conversation highlights the importance of entropy in determining reaction spontaneity.
brake4country
When solid potassium chloride is dissolved in water, the energies of the bonds formed are lower than the energies of the bonds broken. Why does the reaction proceed anyway?
(A) Undissolved potassium chloride compensates for the portion that dissolves
(B) The reaction does not take place under standard conditions
(C) The electronegativity of the water is increased by the interaction with potassium and chloride ions.
(D) The increased disorder due to the mixing results in an increased entropy of the system.
na
I solved this problem by process of elimination, but I must wonder: if the energies of the bonds formed are lower in energy, doesn't this imply that the products are more stable? Wouldn't it also imply that if this reaction were plotted as a bell-shaped curve, that it would resemble that of an exothermic reaction?
"Stable?" Double and triple thinking things does not lead to increased understanding. Heat of fusion is it.
The reason I ask is because the solution states "if the bonds formed have lower energy than the bonds broken, the reaction is endothermic". I thought that lower energy would result in an exothermic process. What am I missing here?
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
