Heat Transfer black-body cube Problem
To determine how many days it takes for a perfect black-body cube (0.0100 m on a side, 30 degrees C) to radiate the same energy as a 100-watt light bulb in one hour, one must apply the Stefan-Boltzmann law to calculate the power emitted per unit area. Knowing the total surface area of the cube allows for the calculation of its total power output. The energy emitted by the light bulb over one hour is 100 watt-hours, which can be converted to joules for comparison. By dividing the total energy from the light bulb by the power of the blackbody, the time required for the blackbody to emit that energy can be found. The result will likely indicate a significantly longer duration, expressed in days, due to the lower power output of the blackbody compared to the light bulb.
Marc Briancon
How many days does it take for a perfect black-body cube (0.0100 m on a side, 30 degrees C) to radiate the same amount of energy that a one-hundred-watt light bulb uses in one hour?
If someone could point me in the right direction with how to go about solving this problem i would greatly appreciate it. I don't want to just be given the answer but shown how to go about solving this problem so that I can learn from the process. Thanks.
Science news on Phys.org
You know the total surface area of the blackbody.
You know, from the Stefan–Boltzmann law, how much energy per unit time (power) a blackbody emits in EM radiation *per unit area.*
Therefore you know the total power of the EM radiation being emitted by this cube.
You know how much energy is emitted by the light bulb in one hour because you know its power.
Since you now know the power of the blackbody, you can calculate how much time it takes for it to radiate that amount of energy.
There you have it -- step by step.
Since the wording of the problem indicates you're expected to get an answer in days, you would expect the power of the blackbody to be much lower than that of the light bulb since it is taking such a significantly longer amount of time to radiate 100 watt-hours worth of energy.
Thank you so much for replying.
I need to calculate the amount of water condensed from a DX cooling coil per hour given the size of the expansion coil (the total condensing surface area), the incoming air temperature, the amount of air flow from the fan, the BTU capacity of the compressor and the incoming air humidity. There are lots of condenser calculators around but they all need the air flow and incoming and outgoing humidity and then give a total volume of condensed water but I need more than that. The size of the...
I was watching a Khan Academy video on entropy called: Reconciling thermodynamic and state definitions of entropy. So in the video it says: Let's say I have a container. And in that container, I have gas particles and they're bouncing around like gas particles tend to do, creating some pressure on the container of a certain volume. And let's say I have n particles. Now, each of these particles could be in x different states. Now, if each of them can be in x different states, how many total...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
