Heat transfer by infrared radiation (the very basics)
The discussion revolves around the fundamentals of heat transfer, specifically focusing on infrared radiation, conduction, and convection. Participants explore the relationships between these forms of heat transfer, their origins, and their interactions in various contexts, including everyday scenarios and theoretical considerations.
  • Some participants propose that infrared radiation is the fundamental source of heat energy, suggesting that it precedes conduction and convection.
  • Others argue that conduction, convection, and radiation are equally fundamental and interdependent, with no single form being more basic than the others.
  • There is a question regarding whether heat transfer by infrared radiation is possible in a true vacuum, with some asserting that it is, while others express uncertainty about the implications of virtual particles.
  • A participant raises a practical question about the effectiveness of using reflective materials, such as aluminum foil, for reflecting sunlight and retaining body heat.
  • Participants discuss the emission of infrared radiation by air molecules, atoms, and subatomic particles, with varying responses about the conditions under which these emissions occur.
There is no consensus on whether infrared radiation is the fundamental source of heat energy, as some participants support this view while others contest it. The discussion includes multiple competing perspectives on the nature of heat transfer and the role of different mechanisms.
Participants express uncertainty regarding the definitions of vacuum and the implications of quantum physics on heat transfer. There are also unresolved questions about the specific conditions under which various forms of radiation occur.
This discussion may be of interest to individuals exploring the fundamentals of thermodynamics, heat transfer mechanisms, and practical applications of infrared radiation in everyday scenarios.
Cliff Hanley
Q. Regards infrared radiation, conduction and convection, is infrared radiation the starting point, the fundamental source of heat energy (thermal energy), and the fundamental source of the other two?
I’m thinking that the Sun predates the Earth by 30 million or so years so the first heat energy put into the Earth was infrared radiation from the Sun. This in turn has caused, over the aeons, much conduction and convection but are those two forms of heat transfer by-products of the more basic form, ie, radiation?
I’m also thinking in terms of convection in a living room. Convection (the movement of air of varying density circulating the room?) is the main way in which the room is heated but the starting point for the process is radiation (from the radiator), yes?
Science news on Phys.org
From bbcbitesize (re infrared radiation);
"Because no particles are involved, radiation can even work through the vacuum of space. This is why we can still feel the heat of the Sun even though it is 150 million km away from the Earth."
Q. I’ve heard physicists talk about ‘the vacuum of space’ not really being a vacuum, ie, it’s not the empty space we once thought it to be, rather it’s actually a ‘bubbling brew of virtual particles popping in and out of existence at every moment’; would heat transfer by infrared radiation be possible in an actual vacuum (an actual empty space), or rather across an actual vacuum (in an actual vacuum there would be nothing to transfer the heat from and to, yes?) ?
Q. In an episode of Auf Wiedersehen Barry and Moxy were sunbathing with tin foil placed beneath their chins in the hope of reflecting the sunshine on to their faces; does this work?
Q. And why are people who are trying to keep warm (eg, when a swimming pool has been evacuated for some reason and the bathers have to hang around outside) sometimes covered with large sheets of (what looks like) aluminium foil? Wouldn’t that reflect any heat energy when the purpose would be to absorb it, no?
"Infra-red radiation (also called thermal radiation)
transfers heat between all objects."
Q. Including air? As well as molecules of air being heated by, to a small extent, conduction, and circulating due to convection; do those molecules also radiate thermal energy?
Q. Do atoms emit infrared radiation?
Q. Do subatomic particles emit it?
No. None of them are more fundamental than the others. Remember that thermal energy is the energy an object has that is stored in the random vibrations and other motions of its composite particles. So a hot gas has thermal energy because the gas molecules are bouncing around, vibrating, rotating, etc.
Again, no. Radiation is not more basic or less basic than either of the other two. Also, the Sun serves as the main source of heat here on the Earth's surface, but plenty of heat still comes from inside the Earth.
No, both radiation and convection are involved (and conduction too I'm sure). There is no 'starting point'. The radiator heats the room via all three methods.
Don't even worry about virtual particles or anything else having to do with quantum physics right now. You need to learn classical physics first.
Of course.
It reflects the IR radiation from their bodies back onto their bodies, where it is absorbed.
Yes.
Yes and no. What you're talking about is known as black body radiation. It is the radiation emitted by an object by virtue of being above absolute zero. This radiation is simply standard EM radiation with a well known spectrum that changes depending on how hot the object is. Hotter objects emit more radiation at higher frequencies than cooler objects do. The Sun, by being at nearly 6,000 kelvin, emits strongly in the visible light region of the spectrum, but it also emits some amount of every frequency up to that point too (and a little bit beyond the visible range). This includes radio waves, microwaves, IR radiation, and a small amount of UV radiation. An object at 20,000 kelvin, perhaps a blue supergiant star, will emit LOTS of UV radiation. In fact, it's peak emitted wavelength is 144 nanometers, which is well into the UV part of the EM spectrum.
Now, a single atom or molecule cannot emit EM radiation that follows this well known spectrum. It may emit specific frequencies that fall within the IR band, but it will not emit a wide band of frequencies like a hot object does.
No, for the exact same reasons I just listed.
Yes it would. IR is just another form of electromagnetic radiation. just higher frequency than radio waves and a little lower in frequency than visible light.
As such, it doesn't need a medium to travel through
try it ...don't blind yourself with the brightness
aluminised mylar foil has a shiny side and a dull side ... it serves 2 purposes
These things are commonly called survival blankets. they can be used in one of 2 ways.
1) to keep a person warm, the shiny side goes towards the body to reflect heat back to the body. The dull side facing out will absorb some heat and also transfer that to the body.
2) If the person is overheating, the shiny side can face outwards so the person doesn't absorb any more heat from the surrooundings
air is a very poor conductor of heat, and convection is the main carrier of heat in it. IR for the most part passes straight through it
yes ... that's the source of IR radiation ( see the next answer for clarification)
The increasing and decreasing energy levels of the electrons ( within the atom) are the source if IR radiation
Other sub-atomic particles as a source, I'm not sure ... some one else may answer?Dave
davenn said:
not sure that is correct mate .
I should probably clarify that I meant that single subatomic particles do not emit thermal radiation. Groups of them can though.
I vote no- these three mechanisms of heat transfer are all handled differently. For radiation, the starting point is the radiative transfer equation (radiometry):
https://en.wikipedia.org/wiki/Radiative_transfer
For thermal conduction, it's typically a diffusion-type equation:
https://en.wikipedia.org/wiki/Heat_equation
And for convection, you must introduce fluid motion as heat is advected by the fluid- a starting point are the mass, momentum, and energy balance equations.
Similarly for sources of heat: the Earth is heated both by the sun (radiation), but also from internal radioactive decay and the 'primordial heat':
https://en.wikipedia.org/wiki/Earth's_internal_heat_budget
Thanks for your reply.
“Remember that thermal energy is the energy an object has that is stored in the random vibrations and other motions of its composite particles.”
For energy to be stored in the particles of an object is something I can begin to get my head around but for it to be stored in the vibrations of these particles is something that puzzles me. Particles are concrete things, yes? They are objects, yes? But a vibration is something that a thing does, it is not a concrete thing itself, no? A vibration is more abstract, no? This is similar to my puzzlement over particles, eg, an electron, *having* negative charge; does it *have* negative charge? Or *is it* negative charge?
“…the Sun serves as the main source of heat here on the Earth's surface, but plenty of heat still comes from inside the Earth.”
And that energy that’s inside the Earth didn’t come from the Sun? Where did that come from?
“No, both radiation and convection are involved (and conduction too I'm sure). There is no 'starting point'. The radiator heats the room via all three methods.”
But if we go back to when the radiator was first installed one of the three types of thermal energy transfer must have taken place first, no? We install the system and switch it on. The boiler heats the water. The hot water in the radiator heats the surface of the radiator and the surface then radiates heat energy into the air in the room, no?
“Of course (re sunbathers using foil to reflect the sunlight onto their faces).”
So they get the direct sunlight from the Sun on their face and then they *add* to this by getting the sunlight that would otherwise hit their chest/shoulder area? Would it be significant? Or negligible?
“It reflects the IR radiation from their bodies back onto their bodies, where it is absorbed.”
So they miss out on the heat that is being reflected but this is negligible in comparison with the heat that they would lose if the heat leaving their bodies was not reflected back into their bodies? Why don’t wee see more aluminium foil clothing around in the winter? Does it have to be directly next to the skin?
“The Sun, by being at nearly 6,000 kelvin, emits strongly in the visible light region of the spectrum, but it also emits some amount of every frequency up to that point too (and a little bit beyond the visible range). This includes radio waves, microwaves, IR radiation, and a small amount of UV radiation.”
But not x-rays nor gamma rays? Also, I’ve been looking at images of the EM spectrum and most have 10^3 m next to radio waves re their wavelength. I assumed that they were therefore all around that length (a km or so) but have since read that they range from as short as 1mm to as long as a km or so; is that correct?
“144 nanometers”
I am finding the discovery of these very small (and very large) measurements / quantities a profound experience. Nanometres, picometres, femtoseconds etc; does this mean that a metre (and a second) can be divided ad infinitum? Take a millimetre. A nanometre is one millionth of a mm, yes? So the mm can be divided into (at least) a million parts. Can we keep dividing it without end?
And a femtosecond is 10^-15 seconds, one quadrillionth of a second. That is profound. A second consisting of a thousand trillion parts / instances. So, a thousand trillion events (at least) can occur during one second? Can we divide the second ad infinitum also?
“It's not about what's possible, it's about what's probable.”
Very thought-provoking quote. At the risk of sounding pedantic, does this really mean it’s about what is highly probable (if something is possible it is probable, no (even if it has an extremely low probability)? Also, determining what is possible is a vast task, yes?
Hi Cliff.
I'm having some trouble with quoting text at the moment, so I'll have to get back to you at a later point (otherwise I'll never be able to keep track of your questions).
Sorry!
P.S. I'm sure it's a problem with my browser, but I'd like to blame @Greg Bernhardt anyways.:-p
Cliff
you really need to learn to quote properly ... its real easy to do
its hard to tell who you are quoting ? ... I recognise some of my own text
think of the energy in sound waves ,,, they are created by the vibrations of say a speaker cone or say an explosion
no it didn't, its the remaining heat from when the Earth and the other planets condensed and formed out of the gas clouds
the gravitational collapse of the gas and other material clouds would generate the heat
yes correct ... is there a question / mis-understanding ?
a significant addition drastically decreases the time till you sunburn
cuz its not fashionable
The sun is an intense emitter of X-rays and a considerable amount of gamma rays too
here's a link on solar gamma rays ... http://today.slac.stanford.edu/feature/gammaraysfromthesun.asp
The sun emits energy right across the EM spectrum from wavelengths of many 10's of metres to those of micrometre length
IR,, visible light, UV, x-rays and gamma rays are ALL substantially shorter in wavelength than 1mm
don't think so ... do some googling on the Planck Length
I will let Drakkith respond to his signaturecheers
Dave
davenn said:
Cliff
Thanks, davenn. This is me attempting now to use the '+Quote' feature; please bear with me if I don't suss it straight away (I'm guessing I simply insert my responses in between each of your separate quotes?). I was quoting Drakkith only in that last post, it was a reply to his post from Sep 8 (post #5). When I clicked on 'Reply' under his comment I assumed it would come up addressed to him. think of the energy in sound waves ,,, they are created by the vibrations of say a speaker cone or say an explosion
So the speaker vibrates, which causes the air to vibrate, which causes my inner ear to vibrate, which is interpreted by a region of my brain? I'm still struggling as to whether the actual energy resides though; in the atoms that constitute the speaker?
And did that heat come from the big bang originally? If so, what kind of heat was that; radiation, convection or conduction? Or are there other types of heat energy?
That was in reply to Drakkith saying that there was no 'starting point'. I may have misunderstood him.
So not a good idea? Unless you use suitable protection cream and then it would be a good idea - for those wanting a suntan?
What about a foil lining with a non-foil fabric on the outside? One for Dragon's Den perhaps... The sun is an intense emitter of X-rays and a considerable amount of gamma rays too
IR,, visible light, UV, x-rays and gamma rays are ALL substantially shorter in wavelength than 1mmThanks. What's the range of wavelengths for radio waves?
don't think so ... do some googling on the Planck LengthThanks. What about time; can a second be divided ad infinitum?
Dave
Thanks. Very helpful.
Sorry, davenn, I've messed up the above reply. How do I insert responses to the various quotes within your post (the way you have done with your last reply to me)?
Highlight the text you want to quote and a small popup will appear. Then hit reply in the popup to immediately quote that text in the reply text box. Or you can hit quote to add that text to a quote que. You can add multiple quotes to the quote que and when you are ready to reply, just scroll down and click Insert Quotes.
The Earth started out hot. So hot that for a long time it radaited/lost far more heat to space than it gained from the sun. What do you think the balance is like today?
It depends on the heat source. A hot water filled "radiator" emits heat by radiation, conduction and convection but not necessarily in equal amounts. Electric bar fires (incandescent type) emit most of their heat by radiation.
Cwatters, you said, “The Earth started out hot. So hot that for a long time it radiated/lost far more heat to space than it gained from the sun. What do you think the balance is like today?”
Given that you’ve said that, ‘for a long time…’ it sounds like you’re implying that it’s no longer the case so my guess is that the Earth now gains more heat from the Sun than it loses to space.
Q. What was the source of the Earth’s original heat? The singularity re the big bang? Was that the source of all the heat in the universe today?
I answered that way back in post #12
No there is more to it. There is more than one heat source involved. There are nuclear reactions going on in Earth's core that generate new heat. As I understand it the planet as a whole is still cooling very slowly. I read somewhere that its only lost about 30% of its original heat so far.
The temperature is only falling slowly because the planet core is well insulated. One source says the planet looses only 50TW which is very small.
no, they are not occurring in the core ... The radio active elements are primarily confined to the lithosphere and mantle and that is where the heat from the decay is being generated. ...
http://physicsworld.com/cws/article...ctive-decay-accounts-for-half-of-Earth's-heat
http://www.livescience.com/15084-radioactive-decay-increases-Earth's-heat.html
The core heat is from the original formation of the earthDave
Davenn, you said,
"I answered that way back in post #12 [what was the source of the Earth's original heat]"
You explained about gas clouds condensing to form the Earth but I meant further back, ie, the source of the heat energy in the gas clouds and whatever preceded them and so on -right back to the big bang. Was the singularity the original source of all the heat energy in the universe today?
Cwatters, you said,
"There is more than one heat source involved."
But which is greater; the heat energy gained from the sun, or the heat energy lost from the Earth to space? And was the singularity the original source of all the heat energy in the universe today?
The big bang didn't have a point origin, as in an explosion and expanding out
there's been many threads on PF on the currently understood understanding of this .. try some searching
Drakkith and phinds are 2 common contributors
You don't need to go any further back than the solar nebula to find the source of the internal heat in any of the planetsDave
from wiki ...
The Earth receives 174,000 terawatts (TW) of incoming solar radiation (insolation) at the upper atmosphere.[5] Approximately 30% is reflected back to space while the rest is absorbed by clouds, oceans and land masses. The spectrum of solar light at the Earth's surface is mostly spread across the visible and near-infrared ranges with a small part in the near-ultraviolet.[6] Most people around the world live in areas with insolation levels of 150 to 300 watt per square meter or 3.5 to 7.0 kWh/m2 per day.
again from wiki ...
Earth's internal heat budget
Global map of the flow of heat, in mW/m2, from Earth's interior to the surface.[1] Higher heat flows are observed at the locations of mid-ocean ridges, and oceanic crust has relatively higher heat flows than continental crust.
The flow of heat from Earth's interior to the surface is estimated at 47 terawatts (TW)[1] and comes from two main sources in roughly equal amounts: the radiogenic heat produced by the radioactive decay of isotopes in the mantle and crust, and the primordial heat left over from the formation of the Earth.[2]
Earth's internal heat powers most geological processes[3] and drives plate tectonics.[2] Despite its geological significance, this heat energy coming from Earth's interior is actually only 0.03% of Earth's total energy budget at the surface, which is dominated by 173,000 TW of incoming solar radiation.[4]
Dave
Reposted for clarity;
Drakkith, you said,
For energy to be stored in the particles of an object is something I can begin to get my head around [I think] but for it to be stored in the vibrations of these particles is something that puzzles me. Particles are concrete things, yes? They are objects, yes? But a vibration is something that a thing does, it is not a concrete thing itself, no? A vibration is more abstract, no? This is similar to my puzzlement over particles, eg, an electron, having negative charge; does it have negative charge? Or is it negative charge?
So they get the direct sunlight [IR radiation] from the Sun on their face and then they add to this by getting the sunlight that would otherwise hit their chest/shoulder area? Would it be significant? Or negligible?
So they miss out on the heat that is being reflected [due to wearing the foil blanket] but this is negligible in comparison with the heat that they would lose if the heat leaving their bodies was not reflected back into their bodies? Why don’t we see more aluminium foil clothing around in the winter? Does it have to be directly next to the skin?
But not x-rays nor gamma rays? Also, I’ve been looking at images of the EM spectrum and most have 10^3 m next to radio waves re their wavelength. I assumed that they were therefore all around that length (a km or so) but have since read that they range from as short as 1mm to as long as a km or so; is that correct? And is 6000K equal to 5,726.85C?
“144 nanometers”
And a femtosecond is 10^-15 seconds, one quadrillionth of a second. That is profound. A second consisting of a thousand trillion parts / instances / units. So, a thousand trillion events (at least) can occur during one second? Can we divide the second ad infinitum also?
Very thought-provoking quote. At the risk of sounding pedantic, does this really mean it’s about what is highly probable (if something is possible it is probable (even if it has an extremely low probability), no? Also, determining what is possible is a vast task, yes?
Shot gunning questions is a poor use of these forums. Doing so without proper use of quote tags is bad form. Just now I highlighted a portion of your message, clicked on "+ Quote" in the pop-up that appeared and then clicked "Insert Quotes" in the message panel down here where I am typing. Easy.
Our units can be divided ad infinitum. No matter how small the unit, we can divide that unit into 1000 pieces and come up with a new unit. The mathematical field of study called "real analysis" goes into that sort of thing in some depth.
The fact that we can define a unit does not ensure that it is meaningful. Units smaller than the resolution of our instruments are of little use. Quantum mechanics imposes difficulties on our abilities to measure the very small or the very brief.
Energy isn't stored 'in' the particles themselves, but in their motion and relative positions. Vibration is a motion and a collection of particles vibrating back and forth (kind of like a spring with two balls on the end that move back and forth) have energy due to this back and for motion. Opposite charges also have potential energy when they are separated. If allowed to, they will accelerate towards each other, turning this potential energy into kinetic energy.
Most of it is left over energy from the formation of the Earth. When the gas and dust of the early solar nebula collapsed to form the Earth it was heated to thousands of degrees, which is why the Earth was initially molten. Over the past 4.5 billion years or so the Earth has lost some of that energy, which is why the crust has cooled down and solidified. But there's still plenty of energy left, as most of the inside of the Earth is still extremely hot.
The point is that none of the three ways of transferring heat is more fundamental than the others, no matter how you set up your heating system.
Yes, that's pretty much it. The light that hits the reflector would have hit somewhere else (perhaps somewhere else on their body or the ground) but is instead reflected onto their face. The result can be significant if the reflector is a good reflector of UV.
It has to face the person's body, yes. They would miss out on the incoming IR radiation from the surroundings, but most of the time the surroundings are at a much lower temperature than the person's body, so they would lose heat to the surroundings. The blanket keeps this from happening by reflecting that IR back onto them.
The Sun doesn't emit much X-ray or gamma radiation by virtue of its temperature. However, the Sun isn't just a hot, static object. It's a ball of hot plasma and there are many different things going on near the surface that emit other types of radiation other than blackbody radiation.
You can indeed.
Yes and yes.
I'm guessing that you heard that heat can't be transferred across a vacuum, but then you thought, "Well how does the Sun heat the Earth across the vacuum in between?", and then you thought "Hey! I heard physicists talk about how vacuum isn't really vacuum but has virtual particles pop and an out of existence. Maybe that's how the heat of the Sun gets across the vacuum of space to the Earth!" That's all totally wrong. Heat is the transfer of kinetic energy from some molecules to other molecules, through collisions between molecules, and that obviously can't happen without molecules in between. Obviously, no heat can be transferred across the vacuum of space. It is electromagnetic waves from the Sun that interact with the Earth that increase the temperature of the Earth. You use phrases like "infrared radiation", and most people here are assuming that you are referring to infrared light which is part of the electromagnetic spectrum, but from the context, I strongly suspect that you are using the phrase "infrared radiation" to mean "heat", because you are not really clear what heat is or what infrared light is. You're not puzzled as to how we can still see the Sun despite the vacuum in between Earth and the Sun. Yet you are puzzled as to how we can feel the heat of the Sun despite the vacuum between the Earth and Sun. There is no heat being transferred from the Sun to the Earth. There are electromagnetic waves that travel from the Sun to the Earth. Heat and temperature have to do with the kinetic energy and collective motion of atoms and molecules. Infrared light is part of the electromagnetic spectrum, in the same way visible light is part of the electromagnetic spectrum. Infrared light has a longer wavelength than visible light.
Obviously nothing, heat can certainly be transferred through a vacuum by radiation.
Of course there is. Heat transfer via radiation is one of the three modes of heat transfer, the other two being conduction and convection.
  • · Replies 20 ·
12K
  • · Replies 17 ·
